Oil Doc said:With the main ingredient as Stoddard Solvent, there is no lubrication. I used Stoddard for parts cleaning years ago when I had a shop.. Dryed the heck out of your skin and just blew the parts dry.
Kerosene has more lubricity than Stoddard and it even causes excessive wear when blended with diesel.. I would definitely make sure to run a lube additive.
Something like this, which is made specifically for Heavy Duty Diesels. AMSOIL ADF
Diesel Concentrate Performance Fuel Additive (ADF)
Total system cleaner and lubricity improver for all types of diesel engines. Improves the performance, fuel efficiency and longevity of diesel engines while reducing deposits, black smoke and emissions. Improves fuel economy by cleaning dirty injectors and restores horsepower. Designed for use in heavy-duty diesel engines.
Doc
mrutkaus said:So there might be something to the old stories about putting mothballs in your gas tank to increase miliage?
Mike
I would be intrested in knowing experiances from any B100 users of those products.DieselPower said:Actually a case of DZL-PEP is $163.44 and a 6 gallon pail is $209.40. Knock off 20% this month for the June special they are running and it's $130.76 for a case and $167.52 for a 6 gallon pail. There is no minimum order. Orders over $300 ship free and orders under $300 incur a $20 handling fee.
gemini5362 said:I talked to my chevrolet dealer about addying additives to my duramax. He printed out a notice from GM. GM does not reccomend adding any aditives at any time. If you do add adatives make sure that they do not contain isopropyl alcohol. The only one that they do reccomend is Stanadyne (sp).
As long as I have a warranty on my duramax and the repairs are expensive I am not going to add anything to it. After the warranty wears off if I dont trade it in for a new one I might consider doing that then.
