Diesel Fuel Additives
   / Diesel Fuel Additives #1
sld
Veteran Member
Midwest
Ford 1210 / Ford 1710
Hi guys,
I have noticed a lot of stuff lately with the ULSD being used in older engines.
Can someone point me in the right direction as to what additives I should add to prevent any problems? My tractor is a Ford 1210 diesel that has run great for 22 years. I would like to keep it that way.
Thanks,
   / Diesel Fuel Additives #2
In the above freezing months I use Power Service Diesel Kleen +Cetane Boost (gray bottle) and then in the winter months I use the Diesel Fuel Supplement +Cetane Boost (white bottle). Never had a problem with starting or engine smoke and use it in my old Ford F-350 diesel as well.
   / Diesel Fuel Additives #3
Personally I use Texas Refinery Corp.'s DZL-PEP or DZL-PEP Arctic depending on the season.
   / Diesel Fuel Additives #4
In the above freezing months I use Power Service Diesel Kleen +Cetane Boost (gray bottle) and then in the winter months I use the Diesel Fuel Supplement +Cetane Boost Never had a problem with starting or engine smoke and use it in my old Ford F-350 diesel as well.
I use 32 ounces (white bottle). per each 55 gallon drum of diesel.
   / Diesel Fuel Additives #5
No powerservice for me since UOA from DysonAnalysis were not good. SKip it.
   / Diesel Fuel Additives #6
You don't have much choice in the winter if your in colder climates. You either use a anti-gel additive or don't use your equipment.
   / Diesel Fuel Additives #7
I would not say that is 100% correct. There are better products then PS.
   / Diesel Fuel Additives #8
Not good in what way? What was the problem?
   / Diesel Fuel Additives #9
IMHO DieselPower is the "guru" about diesel fuel additives. That said I use PS (White Bottle) year round, double strength during the colder months. I have not had my ULSD :( gel up :mad: since I started to use PS. I have heard that Howes makes and additive that is pretty good as well. BTW welcome to TBN sld :D! Jay :)
PS: Long time since I have seen a post from you DieselPower. I missed your avatar :rolleyes:
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
