Egon
Epic Contributor
Some of the new gas engines are getting a little more particular with the type of oil they require.
Ahh, yes, the "ZDDP" controversy. Much discussion/debate ongoing. Supposedly, the new CJ-4/SM iteration is okay as regards valve-train wear, with boron, and maybe something else, replacing the lost zinc/phosphorous, but I think the jury's still out on that one. There seem to be way too many cam issues reported, primarily among gassers running SM rated oil, to blame it ALL on faulty cam or lifter construction, as some seem wont to do. I mean, if an engine that's worked fine for 20-30K miles on SG/SH rated oil suddenly wipes the cam after a change to SM, I'd be looking at the oil, not the cam.RickB said:Many current S-rated engine oils have REMOVED zinc and other trace ingredients for modern engines/emissions standards. These oils are actually WORSE for older solid lifter spark ignition engines than older oil technology S-rated oils or current diesel rated engine oils. Current advise is to use S rated oils on modern gassers but stick with a c-rated oil of the proper viscosity for diesels and solid lifter gassers.
DieselPower said:Many modern gas engines use viscosity's as low as 5W20. Using a 15W40 viscosity oil is going to effect your fuel economy.
Farmwithjunk said:I've heard from what I consider a reliable source that C rated oils aren't good for use with gas engines equipped with catalytic converters. Anyone want to address that?
Iron Horse said:We use Castrol RX Super 15W40 in everything we own (even the hydraulics)but dont have the cold weather you guys get . As stated earlier Diesel oil has more detergent in it to cope with the soot , it will cause no harm in a petrol engine . But do not use it in a Propane engine . Propane has an acidic by product that attacks the white metal on engine bearings . You must also not use normal petrol engine oil in a Propane engine for the same reason . I have seen bearings stripped of all white metal within 25,000 miles . You must use an oil such as Penrite HPR Gas to prevent bearing failure .
