Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
</font><font color="blue" class="small">( Yup, it sounds like you agree that what I mentioned earlier is not "average" use. I mentioned running my tractor at full throttle at 100% capacity in thick boggy mud, running the hydrostadt and hydraulics constantly, for a 1/2 hour period as an example of non-average use. You posted that it "sounds average" to you. I was simply trying to verify to you that what I spoke of is definitely not "average" use )</font>
But see.. what throws the argument a bit is you claiming that you are running it at 100% capacity. ( it does not sound like you are running at 100%.. more like 100++% )
If you really are running at 100% of rated capacity.. you aren't overloading it. Sounds like you really should be saying that i run my tractor at 100% rated output.. and then for about a half an hour here and there i push it to 125% and lug and almost stall the engine out.
Now that.. I would agree.. is not 'average' use. Simply running it at full rated power would be average use.
</font><font color="blue" class="small">( if I were to overload it's rating, it's duty cycle would drop from 100% or I'd significantly shorten it's lifespan. )</font>
IMHO.. the genset would be the weak link.. not the diesel engine. And yes.. I'd think the duty cycle would sharply ramp down from 100% to almost nothing if overload.. -IF- you could overload it. most units I see have load sensitive breakers, or at very least.. thermal breakers.. making it very very hard to electrically overload the genny head.
</font><font color="blue" class="small">( When our power goes out, I want to be able to hook up everything I need; regardless if it is within the window of what my particular genset is rated. )</font>
IMHO.. that's bad planning.. to have more electrical load than genny capability is simply asking for a failure.. and again.. i believe the failure would be on the genny head.. not the power plant.
</font><font color="blue" class="small">( In an "emergency", I'll use it for anything I need, even if it's less than, or considerably over, it's rating )</font>
Less than is fine... unused amperage load is untapped power from the engine... I use my 12.5kw pto genny to power small hand tools inthe field.. doesn't bother me at all to use it to run say.. a hand drill if i am out doing fencing.. etc.
Overlaoding it.. however.. i simply don't do. I've bene around electronics enough to know that electronics simply degrade too fast and experience phenominal failure rates under 'load over tolerance' situations. And electronics usually experience a 'knee-over' and don't come back. For example. You can overload and lug / stall an engine down and reasonable expect it to start back up once the 'stalling factor' is 'cleared' and reasonably expect it to start back up. On an electronic device like a genny head. it's quite easy to introduce an overload situation to it and simply have it give up the ghost on the spot... and not even really have exceded tolerances by much...
</font><font color="blue" class="small">( I've had it hooked up to enough stuff that it ran a constant stream of black smoke out the exhaust. As you know, they don't normally do that )</font>
I'd be very suspicious of that genny output.. if the motor was loaded down that far where it had that much undurned fuel from lugging.. I'd guess rpms were down.. that makes frequency issues, as well as power and voltage issues.
I sure wouldn't want to run any kind of sensitive electronic equipment in that situation.. Depending on the poles in the genny.. as little as a 30rpm drop on the engine can produce frequency problems that anything with a horizontal oscilator will pick up on...
Not to mention votlage problems at load.
We learned full well that you can't overload a genny and expect good performance from it on a job. We specifically learned this while trying to use a genny to power up a well on a job. The well was too uch of a load and droppe dthe votlage output onthe genny to 208vac... at startup. Numbers didn't work out right.. and the pump wouldn't start with any kind of a head or lift... just couldn't kick it over from start to run...Smokes a capacitor on the pump controller finding that out.
Like I said.. if you are running at 100% load.. I don't see a problem. If you lug down to a stall.. well.. that's just a different issue. and IMHO.. even a 'great' oil is not going to completely protect an engine that gets kicked in the 'nads' on a regular basis..
Soundguy
Soundguy
