Diesel prices in your area?
   / Diesel prices in your area? #411
There isn't an advantage to driving an emissions diesel. Pay more up front to purchase, pay more for fuel and pay more for maintenance. Then there are the problems with diesel winter starting and gelling diesel fuel. Since the introduction of the direct injection gasoline engines. The gassers are every bit as efficient or better at turning a btu of energy into mileage as an emissions diesel
Lets hook up a trailer that is loaded to max towing capacity and see how those gassers compare. My F-350 gets about 8 MPG towing a 10K trailer, My Grandpas Duramax gets about 13 MPG towing a 15K load.
   / Diesel prices in your area? #412
The advantage is torque.
How is torque an advantage ? Torque alone does nothing .
What you are thinking of is the reduction of down shifting . The factory shift points in my 6.0 were horrible . It would drop out of OD on the slightest grade and scream up a modest hill in 2nd gear . As a 5 or 6 speed manual could not be ordered. I installed a programmer and set proper rpms and speed to shift. I have had passengers ask if I swapped in a diesel the way it pulls on hills.
How aware are you of the relationship between torque, rpm and HP? Do you know why gassers can cruise at low rpms then rev up to cover momentary peak loads and why diesels can't?
   / Diesel prices in your area? #413
Let's open up the wallets and pay for a new 2016 diesel and a new 2016 gasser with the tow package. Let's fill the fuel tanks and look at the $$$. Let's roll each truck into the shop for seri e every 10,000 miles and look at the bills$$$. Let's run those trucks past the manufactures emissions warranty and price out injector ,turbo, waste gate , glow plug, twin batteries and a particulate filter $$&.
Let's hook up the 355HP or 420HP chev DI gassers and see how they pull. They make more power than the diesels did just a few years ago. I recall 6BT and ISB drivers bragging about 160 to 325HP.
   / Diesel prices in your area? #414
Let's open up the wallets and pay for a new 2016 diesel and a new 2016 gasser with the tow package. Let's fill the fuel tanks and look at the $$$. Let's roll each truck into the shop for seri e every 10,000 miles and look at the bills$$$. Let's run those trucks past the manufactures emissions warranty and price out injector ,turbo, waste gate , glow plug, twin batteries and a particulate filter $$&. Let's hook up the 355HP or 420HP chev DI gassers and see how they pull. They make more power than the diesels did just a few years ago. I recall 6BT and ISB drivers bragging about 160 to 325HP.
I never said a diesel was cheaper because they are not. A diesel will pull circles around a gas. Even with the higher cost of diesel it is still cheaper to run a diesel under heavy load than a gas. A 400 hp diesel can produce over 1500 FP of torque. How much toque does the 420 hp gas produce. My guess is about 500 foot pounds.
   / Diesel prices in your area? #415
4570
You did not pass any classes in physics in high school did you.
Can you tell us the what is torque, HP and rpm ?
Why are you drag racing with a truck and trailer? Do you haul for the Cannon Ball Run? Why do you drive like a mad man with the engine making 400HP continuous?
How much pulling power do you want? A few years ago a 318 was good enough to haul 80,00bs of freight plus the weight of the rig . From coast to coast over two mountain ranges . Now some people think they need 400+ HP in a pickup to haul a horse trailer or motor home
   / Diesel prices in your area? #416
4570 You did not pass any classes in physics in high school did you. Can you tell us the what is torque, HP and rpm ? Why are you drag racing with a truck and trailer? Do you haul for the Cannon Ball Run? Why do you drive like a mad man with the engine making 400HP continuous? How much pulling power do you want? A few years ago a 318 was good enough to haul 80,00bs of freight plus the weight of the rig . From coast to coast over two mountain ranges . Now some people think they need 400+ HP in a pickup to haul a horse trailer or motor home
Torque is a measure of how much force was applied to an object causing it to rotate. Horse power is a measure of work done over time. RPM = rotation per minute. A 400 hp diesel is usually rated at 1800 rpm. You don't have to drive like a mad man to reach that. You probably won't ever reach the rated hp of a gas because of the high rated rpm.
   / Diesel prices in your area? #417
G - 2.35
D - 2.59
   / Diesel prices in your area? #418
Gas prices continue to bounce up and down here.
   / Diesel prices in your area? #419
You were doing well enough with a Wikipedia quote . Then it showed again how little you understand with and after the 400HP stuff.
Tell me is there some NASCAR class for racing pickups and trailers ? Why are you roaring around like a madman with 400HP on a truck with a light weight trailer ? It's not a race .
   / Diesel prices in your area? #420
Tell us please how much towing has to be done in this light duty highway application to make the higher priced truck, higher priced service and higher priced fuel save $$$ over a light gas . Are you aware of the definitions of light, medium and heavy duty applications ?
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
Metal Rooster Statue (A55758)
Metal Rooster...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
