Diesel Storage
   / Diesel Storage #22
Your biggest storage problems are algea and moisture with modern diesel fuels (ULSD).
Is off-road diesel better for storage?
   / Diesel Storage #23
It is widely believed that the only difference between on-road and off-road is the addition of red dye. They are probably the same as they come into the distributor, it would be too expensive to ship and store two different types, so there is only one type produced and shipped.
Ken
   / Diesel Storage #24
Ken
Doesn't Off-road have more sulfur, or is that something of the past?
   / Diesel Storage #25
It is considered doubtful. Would refineries produce two different runs, store, and ship them?
It becomes an important issue since many off road vehicles are older and not designed for ultra low sulfur.
Ken
   / Diesel Storage #26
Off road and road diesel are the same in my area, just the dye is added. For that matter Home Heating Oil is the same as off road.
This varies from place to place but that is how it is here with my 2 distributors.
Chris
   / Diesel Storage #27
Originally Posted by PoorMansCat
See, I don't plan on moving the barrel. I am ALWAYS at the fuel station (at least once a day with my svc. truck)
9*I plan on just carrying a 5 gallon fuel can and filling it up on occasion. When I get home, I can transfer it to the 55 gallon barrel.
10*The hand pump I have looked at will pump both directions,(actually a cheapo from Northern Tools) dependent on which way you turn the crank. No lifting involved, drop the hose in the fuel can, turn the pump one way and it will transfer it into the storage barrel. Turn the crank the other way and it will pull fuel out of the barrel into my Kubota!!.
9*I don't see /understand what you gain by doing this ??
Don't you still have to lift the 5 gallon can to dump it into the barrel jus like you would to dump the can of fuel into your tractor?
10*Why not just get another barrel and use the pump to fill the other drum/barrell and do away with the 5 gallon can/cans compleatly ?
Not in my case, The two way pump will allow me to pump the fuel from the 5 gal. can into the storage drum. THen, when I get ready to fuel my tractor, I will just pump from the drum into the tractor. I believe the pump is called a bi-directional barrel pump.
   / Diesel Storage #28
1*Is off-road diesel better for storage?
1*No because they are both the same stuff.
Off and on road are terms used to describe where the fuel is used not a type of fuel.
2*It is widely believed that the only difference between on-road and off-road is the addition of red dye.
3*They are probably the same as they come into the distributor, it would be too expensive to ship and store two different types, so there is only one type produced and shipped.
Ken
2* & 3* Correct
4*Doesn't Off-road have more sulfur, or is that something of the past?
4*That is a hold over belief from the recent past.
About 95 % of the change over from LSD to ULSD has now been completed.
5*It is considered doubtful that refineries would produce two different runs, store, and ship them?
Ken
5*This would be much more expensive than just producing and storing ULSD .
   / Diesel Storage #29
I have one of those 100 gallon rectangular tanks with flanges on the bottom to bolt it to your truck bed. At one time, it was a necessity to have it on the truck during the summer with a lot of fuel use. During the winter, 100 gallons of fuel provided some weight for my dually to get around in the snow.
Now days, I barely use a 100 gallons a year so I have the tank on a pallet. Come fill up time, I pick it up with my tractor and strap it on the truck. Fill it, set it back off for my occasional use. I just hook up the 12v pump to the tractor battery.
FWIW, for regular use with my diesel truck, Power Service suffices. For my tractor, I go with FPPF Total Power.
   / Diesel Storage #30
2* & 3* Correct
Well, that sucks! I always heard that sulfur is actually better for diesels. Figures they would remove it to only make one run to save $$.
This is my setup I bought for $140. I recently bought new hose, pump, and filter, just need time to get it setup when i get home. I'm thinking I will like gravity feed - pretty foolproof.
Of course, as I was bragging what a deal I got on it to my concrete sub, he told me one of the local oil distributors will supply a free tank for off-road....:mad: I'm assuming that's if you order a LOT of diesel....
Ken - thanks for the reply.
Lbrown - Where are you South of Canton? I'm in Dover. Have you shopped around for oil suppliers?
   / Diesel Storage #31
My 12 volt pump is plumbed up in such a way that i can pump from and or 2 any container.
   / Diesel Storage #32
1*Well, that sucks! I always heard that sulfur is actually better for diesels.
2*Figures they would remove it to only make one run to save $$.
3*Lbrown - Where are you South of Canton? I'm in Dover.
4*Have you shopped around for oil suppliers?
1*Nothing wrong with ULSD now but at first there were some bugs that had to be worked out.
2*That is not the reason that it was done .
It was an EPA issue.
Had they not done it fuel would probably cost you more per gallon than it does now.
3*Marietta at the the end of I 77 in Ohio.
4*We had 4 suppliers / distributors here .
One of them closed up shop .
With my luck it was the one I was using and offered free delivery.
I now haul my own.
   / Diesel Storage #33
cool... I have a 1/2 in peanut pump.. but that seems like complete overkill... besides, I would have to run an air line.
   / Diesel Storage #34
LB,
are you sure about that? My understanding is that older engines expected the better lubricity properties of higher sulfur fuel and they are not getting adequate lube from ULSD.
I've heard that adding marine two cycle oil helps significantly.
Ken
   / Diesel Storage #35
http://www.tractorbynet.com/forums/oil-fuel-lubricants/103041-how-do-you-store-your-5.html
This page of previous thread shows my set-up , Page 6 and I discuss it .
I had it filled in '03 ??? , ( know for sure it was before '05 as that was when we got our new house ) . A can of fuel conditioner or similar every year and thats been it . Down to maybe a third left with no problems yet . Pull tractor right up in front and crank the handle .
Fred H.
   / Diesel Storage #36
Im my area we still have LSD. The pumps still list the off-raod as LSD 15PPm or whatever. Talked to the distributor i just bought 55 gallons at $2.69 and he said yes its LSD. The place 50 miles down the road i got 10 gallons a few weeks ago had LSD printed on their receips, so i guess still have LSD off-raod, i failed to notice the pump though. My guess is that they would have used the ULSD slot on the recipt if it was really ULSD.
This seems to come up every 3-4 months.
   / Diesel Storage #37
Let's hope your ethanol in petrol pushers don't try something similar with diesel as they have over here.
Over here red diesel will have to be ULSD from January, and most of it will be dyed road diesel which also contains 7% biodiesel.
This is putting me off buying in bulk now - with all stories of bacterial growth and water absorbtion - so I shall stick to 20L jerry cans.
J
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
JOHN DEERE 6140M TRACTOR (A60430)
JOHN DEERE 6140M...
John Deere XUV825E (A56438)
John Deere XUV825E...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
