Difference between 4WD and MFWD tractors, updated
   / Difference between 4WD and MFWD tractors, updated #11
People get hung up on this?
I don't think it's a either/or, but rather that MFWD is a subset of 4WD (i.e. one particular type of 4WD).
...and if you think about it: A MFWD (mechanical front wheel drive) tractor is NOT a front wheel drive tractor. Engaging the front wheels doesn't turn off the back wheels. Or it shouldn't! It's a 4 wheel drive tractor!
So yes (IMHO), a MFWD is a 4WD.
...that being said, I won't say a AWD vehicle (i.e. with a center differential instead of a transfer case) is a 4WD, or vice-versa. Even when ALL the number of wheel equals Four. That's the thing with language, it evolves and changes, sometimes to a point where the "definition" isn't the literal meaning, but more the "common use" meaning. Who's to say what's right or wrong?
Me! ;)
Does a snowblower really blow the snow? Nope. It's not pneumatic! It's a snow thrower. Or call it a snow pump, whatever, but it's not a blower!
Sorry for the rant, I'll stop and go "dust the furniture" now! Won't the wife be surprised! :D
   / Difference between 4WD and MFWD tractors, updated #12
Unfortunately that line has become very much blurred. I often see dealers and even manufacturers using 4WD instead of MFWD. Checking tractor listings requires a double search because the same tractor may be listed either way.
The line only got blurred when the townies moved to the country and started buying little tractors, so the "new" dealers took on their lingo, to sell more tractors to them... lol
Back when farmers, WERE farmers, this question never came up, EVERYONE knew what a 4wd was and what a MFWD was... Even what "front wheel assist" was/is...
There you have it, so bash me for saying the truth...
SR
   / Difference between 4WD and MFWD tractors, updated #13
SR
Very well stated, and the truth of it. Only people offended will be those you mentioned in the beginning. :)
   / Difference between 4WD and MFWD tractors, updated #14
Simple, go to JD, the largest tractor manufacturer by sales in the world. 4WD is a large, 4 wheel or track drive articulated tractor. MFWD are the non-articulated tractors, 2 large tires in the rear, 2 smaller tires in the front, both front and rear can be dialed, and the drive to the fronts is disengaged either automatically (larger tractors) or mechanically for roaring because tires are not of identical size. But that’s technical terminology. What you want to call it is whatever you want.
SR
Booooooooooooooooooooooooooooooooo, Baaaaaaaaaaasssssssssssssssssssssh, I dont like that answer..................
My tractor is not a Mechanical Front Wheel Drive tractor. It's a Mechanical Four Wheel Drive tractor, with one wheel on front that has Optional Drive Capability ODC, meaning when the tractor gets stuck one wheel just sits there to help hold up the front end................
   / Difference between 4WD and MFWD tractors, updated #16
It seems that those who "doth protesteth too much" are the guys who are always posting some rendition of "My tractor is better than yours"... My woodsplitter is faster than yours" ... "My *.* will pull more wood than yours " And it isn't just those of us with small tractors.
At the end of the day I don't care what you call it, I go farther with the rears locked and the front end engaged. I buy a tool to do the jobs that I need it for, not to get into a ****ing contest about who has the best whatever.
   / Difference between 4WD and MFWD tractors, updated #17
That's because YOUR tractor is special...
BTW, I've been meaning to ask you... Someone sent this to me, and told me it was you!
is THAT really you?? You have some nice deer up that way... lol
SR
SR
No wasn't me, but the distance is about right, last Nov I was facing the other way using a deer call, then I heard a noise behind me when I turned around that deer was heading the other way showing his rack and it's pretty white tail, another one of those wrap the gun around the tree moments...........
   / Difference between 4WD and MFWD tractors, updated #19
Same ole same ole..
Those **** townies with the little tractors.. What are we gonna do...
   / Difference between 4WD and MFWD tractors, updated #20
A bull is a cow, but a cow may not be a full. 4WD has grown to mean anything that can pull with 4 wheels.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2014 HYUNDAI 53FT DRY VAN TRAILER (A59905)
2014 HYUNDAI 53FT...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
