Difference between 4WD and MFWD tractors, updated
   / Difference between 4WD and MFWD tractors, updated #21
cow may not be a bull. old hands make mistakes.
   / Difference between 4WD and MFWD tractors, updated #22
In cars and trucks, 4wd is part time, awd is all the time. Either can have locking mechanisim of some sort on one or more diffs, or none at all. Some modern 4wd trucks have automatic mode, which makes it not that different from some forms of awd.
Another older definition is that 4wd does not have a center diff, awd does. That was true until some car awd systems come out with viscous couplers or computer controlled clutches instead of center diffs.
(the awd's center diff is needed because in a turn the front wheels take a longer path than the rears. That's why a typical 4wd system slightly overdrives the front wheels vs the rear and why they should not be operated on high traction surfaces).
If you see an old International Scout with "four wheel drive" on the cowl it meant that it had what we now know as 4 wheel drive; one powered wheel on each axle. If it said "all wheel drive" the differentials would lock and you had all 4 tires pulling.
   / Difference between 4WD and MFWD tractors, updated #23
The line only got blurred when the townies moved to the country and started buying little tractors, so the "new" dealers took on their lingo, to sell more tractors to them... lol
Back when farmers, WERE farmers, this question never came up, EVERYONE knew what a 4wd was and what a MFWD was... Even what "front wheel assist" was/is...
There you have it, so bash me for saying the truth...
SR
When would you say this occurred? My local dealers of all brands always called a 2wd tractor a 2wd and the same tractor with "front wheel assist" a four wheel drive. I think the line got blurred many, many years ago, and it wasn't the dealers catering to the city folk. See a page from my 1984 International Operators manual for 84 series utilities, a farm tractor that isn't a "four wheel drive".
   / Difference between 4WD and MFWD tractors, updated #24
In 1968 I went to the Iowa Farm Show. I believe it was near Grinnel but not sure. I saw two tractors I'd never saw before.
The first was a John Deere center pivot. Can't remember the model. It was called a 4wd tractor.
The second was an Oliver. Maybe a 2150? It was equipped with FWA. And that's what it was called.
There was no confusion then. Everyone interested in tractors knew the difference.
Obviously in the next 15 years the waters began to muddy. 4wd sounds more manly and tough. FWA sounds weak and inadequate.
That wasn't felt by owners that worked them every day. It was felt by the potential buyers that Rob referred to earlier. :)
   / Difference between 4WD and MFWD tractors, updated #25
   / Difference between 4WD and MFWD tractors, updated #26
BUT, that's in Canada, where they can be standing right next to a generator, and call it "hydro"!! lol
SR
   / Difference between 4WD and MFWD tractors, updated #28
SR
Haha, must be regional, we don't call it hydro in these parts eh? :) More like "power goes out and I start up the generator" IMG_2258.JPG
Check out the back page of the 84 series operator manual. IH US book and printed in USA so technically my Canadian dealer would be right calling it a four wheel drive when selling these in the 80s. Weird since we bought an England built IH in Canada that came with a USA operators manual.
   / Difference between 4WD and MFWD tractors, updated #29
My new Ram Power Wagon has 2WD, 4WD & AWD. I can throw the lever into 4WD and it puts power to both the front & rear drive lines. I can twist the knob and LOCK the front, rear & middle differentials. At that point, I better be in something pretty slick. Power is going, 25%, to each of the four wheels. No slipping in the mid differential nor the front or rear differentials. This last case is what I would call TRUE, 4WD.
Ah, but back when the Oliver 50 series where new it could have been a hydraulic front wheel assist,
Dumont Museum Photo Album
or a mechanical front wheel assist;
and where does this fit in, no way to disengage the front drive here, and it's front steer with equal size tires all around;
Pair of Unique Ford County Tractors in Minnesota | Machinery Pete
I figured it out.................
hydraulic front wheel assist= Hydraulic Four Wheel Drive>> HFWD
mechanical front wheel assist= Mechanical Four Wheel Drive>> MFWD
no way to disengage the front drive = Fulltime Four Wheel Drive>>> FFWD
four wheel drive tractor= FWD = All the above.........
Rubber band front wheel assist tractor = RBFWA <<< Sold by Fred Flintstone and sons...........
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
17307 (A55853)
17307 (A55853)
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
2019 F150 (A56438)
2019 F150 (A56438)
