Difference between a radiant heater and a convection heater ?
   / Difference between a radiant heater and a convection heater ? #1
diesel lover
Platinum Member
whites town indiana
Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
Hey, I'm familiar with radiant heaters as they heat up mostly surfaces but how does a convection heater work? Thank you
   / Difference between a radiant heater and a convection heater ? #2
Your conventional central heating system is a convection heater: It heats up the air and circulates it (or just heats it up and it circulates naturally through the movement of warm air upwards and cool air sinking to the floor.
A stove that is a convection heater may be a pellet stove (which outputs hardly any radiant heat at all), or it could be a wood stove with an air spaced "jacket" that is designed to draw in cool air from ground level and output a plume of hot air above the stove, which will circulate on its own to locations that are cooler (except that warm air will not migrate downstairs from the level the stove is on). The Alderlea series of stoves from Pacific Energy are all convection heaters because they have the cast iron jacket around a welded plate steel stove. However, it should be remembered that there is still a lot of radiation from the glass in the door as well as the top of the stove and the stovepipe itself. So truth be told the PE stoves are a combination of convection heater and radiant heater, whereas a pellet stove with its very cool double wall flue is about as close to a true convection heater as you can get.
I personally prefer either a radiant heater or the combination approach. The big benefit with the combination approach is the small install clearances on the sides and back of the stove, and in the case of the PE, the underside of the stove too. The double wall construction does lower external surface temperatures, so you are much less likely to scorch anything near or under the stove. I can set my boots next to my PE T5 and even if the boots touch the outer cast iron cladding, no harm will be done (it won't melt the shoe laces etc. Now if you try that at the front of the stove, you will get a different result...
   / Difference between a radiant heater and a convection heater ? #3
Another way of thinking of the two is standing in the sunlight will give you radiant heat from the sun whereas standing in the shade only gets convection heat from the surroundings that have heated up from the sun's radiant heat and is then transferred to you via the air. With Radiant heat you basically have to be in direct visual contact with it to get the full benefits. Radiant heat feels much better to your cold body than convection because you get the instant heat sensation rather than the slow warm from heat transferred thru the air as air is not a good conductor of heat which is why we use is for insulation. The benefits of convection heat is that one heat source can heat the whole house quickly compared to the hot wood stove that heats one room extremely hot before convection air currents carry any of the heat to other rooms.
that does make quite a bit of sense to me, thank you
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Adams 16T Tender Body (A56438)
Adams 16T Tender...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
