Diffy housing change by self
   / Diffy housing change by self
I put the hydrolic housing back together. I only need to put the piston housing back on. There are two claw hands. When I took it off I did not see where they grab onto. They are the control levers for the three point. They attach onto two half circles that are each two spaced 1/4 inch apart peaces of metal that the claws sit inside and hold a small circle that moves them around. One claw is about 4 inch diameter and I can't seem to find how it holds into place. See picture 23 and 20 fit ontot the bar but does it fit in the circles or just on the bar?
The Engine is all blocked up and tied down so it will not go anywhere. Then I have to take off the axles and tires. Pull the housing and then rebuild the entire unit.
I took off the axles and housing. It came apart very easily. I used two ladders and make a sling out of a tie down. I really need to by some tools. I needed a 1" 1/16" wrench but only had a 1/8. Used a neighboors. Got everything off. Now I need to get the seals and put everything back together.
I was able to get all the parts out and back on. I had to get a pipe wrench from my neighbor for the PTO shaft. I got going to fast and set it in place without making sure the bolt holes line up. Well with a twist and a backwards walk into my work bench (my presure washer stopped me), after the wrench gave way, everything was lined up. With the wifes help I was able to get the tires on. I used two ladders, board, and a pully system to get the axles on. All I need to do is the top plate and I'm back in action.
Down to putting the top cover off. Then I find that the top plate has a side vent to check for presure. It was cut off on the new one. So I have to drill it out and rethread it.
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2014 NISSAN NV CARGO VAN (A59575)
2014 NISSAN NV...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
