Digging a trench on an incline
   / Digging a trench on an incline #1
lakeside
Ontario and Quebec
B26, G11000 generator and a G1800
I have to dig a 50 foot long 36" deep, trench on a gravel lane that slopes up and down at about 10 degrees. I'm getting my B26 next week :D and this will be one of the very first jobs I'll do with my new baby. I have little (read none) experience with a backhoe so what's the best and safest way to dig the trench? Should the backhoe be facing downhill or up hill? Intuitively, I'd say the backhoe should be facing uphill but the way the trench will be having the backhoe facing down will be a bit easier, but will it be as safe?? :confused:
   / Digging a trench on an incline #2
It should be much better to start at the top and work down, with the FEL on the downside. A backhoe has a strong and annoying tendency to pull the tractor backwards. That will be an even bigger pain if you have the hoe on the downside.
   / Digging a trench on an incline #3
+1 Agree
   / Digging a trench on an incline #4
Yeah,top to bottom,no dirt in your ditch either.
   / Digging a trench on an incline #5
You will find, digging down the grade will work the best.
A couple things that will help... first, start out at a leasurely engine speed until you get used to the backhoe controls. After a little while, the control movements will become more automatic as you gain seat time. Secondly, do the actual digging with the curl function. Trying to dig with the dipper will cause you to continually drag the tractor backwards.
Have fun and take some pictures to post.
   / Digging a trench on an incline #6
I realize you said only 10%, but be careful and maybe dig out some tree roots on flat ground first.. Get familiar with things..
   / Digging a trench on an incline #8
I agree, backhoe on uphill side, FEL downhill, put all the spoils on one side of the trench, if there is a side to side slope, put them on the uphill side.
Think about backfilling before you dig. It is frequently better to have the trench at one side of the driveway, and the spoil pile also on the driveway. If it is wide enough you can keep the machine on the driveway while backfilling that way.
   / Digging a trench on an incline #9
I also agree with top to bottom as being easier, but... depending on your soil conditins and surface water runoff, the trench may have water in it right away. Thus you may be digging in soup/wet conditions when you get toward the bottom as your trench does its job carrying water away. When digging bottom to top, I've been filling my FEL with a full load of dirt to help stabilize it.
Just a couple thoughts.
   / Digging a trench on an incline #10
Don't forget about Water Lines,,Power Lines,,, and other things that might be in the ground in your area..My post light wires are next to my drive,,
(5) Eight Hole 23 Inch Steel Rims (A57454)
(5) Eight Hole 23...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
Pallet of Miscellaneous Power Tools and Fans (A56860)
Pallet of...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
