Disassembling 7360ss shift linkage
/ Disassembling 7360ss shift linkage #1
VetFan
Mims, Florida
Cub Cadet 7360ss
Got both cub cadet manuals. Pics indicate a cover on side of center case, labeled "Lever holder" 4 bolts appear to hold it on and I removed them, but short of destroying it, it refuses to come off and the pics are zero help. I disconnected all external linkage, shift is in neutral. Pics look as if it should come up and off, I would gladly welcome any help. The slide lever is leaking about a gallon of hyd. fluid every 2-3 days even while sitting.
/ Disassembling 7360ss shift linkage #2
The shifter on my 7260 SS works good when it's warm outside, but gets hard to go into fwd or rev when it's cold. I haven't found any lub points. Anyone else with the same problem or suggestions to fix. Was also very hard to start the engine when it's cold, so I put the glow plugs on a manual system with a switch and a 180 amp fuse directly from the battery to the glow plugs. Turn it on for 8 seconds, starts every time.
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2020 BOBCAT T770 SKID STEER (A65053)
2020 BOBCAT T770...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
