DiscountHydraulicHose.com
   / DiscountHydraulicHose.com #41
That is why you use one size larger QD.
It would be easy enough to test.
Connect a full set of QD to a hose and place in a 5 gal bucket and measure the flow,
Then remove the QD and place the hose in a bucket and measure the flow.
I don't believe you will see a big difference.
That's not a valid test of flow restriction in a hydraulic system with a fixed displacement pump (gear, vane, piston, etc). Setup your test as you described, but add pressure gauges before and after the QD, or better yet, a differential pressure gauge. The effect QD's produce is pressure drop, which increases with flow rate. The flow rate will not change (or, by a negligible amount) until you reach a level of back pressure that exceeds system relief pressure or you slow/stall your prime mover (engine).
Besides a reduction in performance of the system downstream of the QD, another downside is heat. Pressure drop x flow = heat input to system. A hydraulic system, under the right conditions (dumping full flow across relief valve), will produce a tremendous amount of heat into the oil. A system driven by a 20 hp engine has the potential to generate around 15,000 watts of heat under those conditions! Just some food for thought when considering the effects of fluid conductor sizing and pressure drop.
   / DiscountHydraulicHose.com #42
My point in using the next higher size QD was about less restriction.
So what you are saying is that hose size/QD size has no effect on GPM's delivered at the end of the hose until relief pressure is met. .
I can understand that as the pump, based on rpm is pumping same volume but at a different pressure until it is slowed down by the end of stroke of a cyl, and the pump now has to force the same volume across the relief valve, therefore testing the engine and pumps ability to produce the GPM at a certain pressure with out stalling.
A lot of people seem to recommend 1/4 in hose for grapple cyl and such thinking it will slow down the action.
The only thing it saves is cost.
   / DiscountHydraulicHose.com #43
It's about the same as adding a needle valve to slow flow.
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
Hay Spear (A53316)
Hay Spear (A53316)
Giyi Mini Vibrating Roller (A53316)
Giyi Mini...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2016 Ford F-150...
