DIY Home built compact tractor
   / DIY Home built compact tractor
kenmac said:
very interesting. Where do you find the time?? Can't wait to see this thing in action
Its hard to find the time lately, I've got a lot of irons on the fire.
I'm presently working on the diesel engine, trying to get it running. I want to do a test drive befor any further fab work, to make sure the ratios and ground speed are going to be acceptable.
Tim
GCLnIndiana said:
How did the test drive work out?
Hasent happened yet. I tested the injectors yesterday, 2 good 1 dribbles & 1 clogged.
I'm going to see if the wrecking yard has any cheap, or I might rebuild them.
Tim
   / DIY Home built compact tractor #235
Just found this post - amazing talent you have!! Any more updates and more pictures???
   / DIY Home built compact tractor #236
need an overall shot.
   / DIY Home built compact tractor #238
Great thread, I also joined because of this. I've been kicking around the idea of building a compact/garden tractor, not quite as ambitious as this but 2wd and around 10 hp.
I used to compete in the tractor pulls with my 4-H club as a kid, with a Garden Master tractor. They had used cut down car parts and a 9hp Briggs to build a small tractor. Managed to pull 5400 lbs with it once. Figured copying it a bit and a more modern engine (the one I used to use was a hand crank, which my dad converted to a loose rope pull start) and newer drivetrain would be a pretty useful machine.
Can't wait to see this one going, are there any more threads on home built tractors?
Thanks,
James
   / DIY Home built compact tractor #239
Tim
Excellent thread. Keep us posted. Can't wait to hear it run.
While you have it apart, I would change the timing belt, real cheap insurance.
What is next, a bio diesel set up??
Will
   / DIY Home built compact tractor #240
With Volkswagen Diesel engines, there is also the small belt on the other end of the crankshaft that drives the fuel pump... I think it has twice the rated life of the main belt (probably because its less risky if it breaks)
But for the secondary belt, a visual inspection (check for rags) should be safe enough.
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53473)
2000 Kenworth W900...
Unused Delta Crash...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
