DIY Root Ripper
   / DIY Root Ripper #2
Found this while surfing youtube and it looks real handy so I thought I would share.
Awesome, and good timing! That is EXACTLY what I had in mind as a possible solution. Now, if someone would just make it commercially.
   / DIY Root Ripper
If you go on the video makers YouTube channel he has a video on how he made it. If I was going to make it I would build it so that it could bolt to my pallet fork frame once the forks are removed. That way it would save on needing a ssqa plate
   / DIY Root Ripper #7
I have a single bottom moldboard plow. Take off the share and I have a very HD single shank ripper. I use it to loosen up stands of Buck brush before removing with my grapple.
   / DIY Root Ripper #8
Sure am envious of his front 3 point. Why the manufacturers don't make it an option here is beyond me.
   / DIY Root Ripper #9
Seems like a good way to tweak your loader frame if you’re not real careful.
Just what I was thinking. That is a lot of stress to be putting on a lightweight homeowner type tractor. And it's not a type of stress that the loader & frame was designed for.
   / DIY Root Ripper #10
I was going to mention the same, then I put it together that between his accent and the front 3pt. that he probably wasn't in the US. This made me wonder if they also get a more robust loader?
I'm under the impression that there's many more smaller working farms around the world depending on smaller tractors for all of their work.
208316 (A58375)
208316 (A58375)
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
