Do you lube your 3-Point linkages?
   / Do you lube your 3-Point linkages? #21
How old does your equipment have to be before you grease your balls? Plus if you use any sprays it tends to burn a wee bit.....
Wow, good thread, funny innuendo too :D
Good ideas. It turns out I have some bicycle chain dry lube, and that seems like a pretty good choice, all things considered.
You guys are great :thumbsup:
   / Do you lube your 3-Point linkages? #23
:eek:Well, I'm staying out of this thread.:eek:
   / Do you lube your 3-Point linkages? #24
I vote for no grease. I am not a heavy tractor user but if there was grease all over my 3 pt hitch and attachments I would be scared to walk in the barn for fear of coming out covered in grease. Even with my limited use my balls stay rust free. Yes I am married with a couple kids.
   / Do you lube your 3-Point linkages? #25
You know, that is a good point. I grease, then I wipe things down, and I still get grease on me. If I did that to the 3pt, I'd be a mess all the time.
Still curious what the BIG DOGS (Mid-West farmers farming 1000's of acres) do.
   / Do you lube your 3-Point linkages? #26
May I suggest spray graphite. I use the stuff JD labels for slip clutches anywhere you need lube(but not bearings of course). It works great. It does not attract dirt or dust, and after a few uses, seems to impregnate in the metal and reduce or eliminate oxidation. I have been using it on the top link, balls, and pivot points on the tractor with no problems. It also works wonders on hinges, gates, squeaky leaf springs, etc.
I tried dry film lubricant but it doesn't seem to work as well or last as long. I use the graphite maybe once a year on tractor and equipment and it lasts all season.
Spray it on but let it flash off before moving the parts.
   / Do you lube your 3-Point linkages? #27
Don't grease thing's! If you do I might be out of a job!
On a serious note the reason we sell so many moving parts, pins and balls included is because people believe greasing things is bad?????
If you own a grease gun and know how to use it then you can own a tractor. If you don't then don't by a tractor. Tractors need grease as much as they need diesel, you can never have to much grease. Tractors are also dirty machines ( yes even the ones that get polished) so if you don't grease a tractor because you are worried about getting dirty don't come crying to me about having to keep replacing parts!
   / Do you lube your 3-Point linkages? #28
Boy...there are a number of posts on this thread...well, if those posters ever end up in prison together...at least they won't be lonely (or bored).
2008 MARIAH SKI BOAT (A54756)
2008 MARIAH SKI...
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
1672 (A54756)
1672 (A54756)
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2019 CATERPILLAR 299D2 SKID STEER (A52705)
2019 CATERPILLAR...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
