RPW
- Joined
- Aug 12, 2009
- Messages
- 1,105
Tom, 1200lb rolls last my 7 horses a little over a week in mild weather. If its cold say less than 30 degrees it will go up. They also graze on about 20 acres.
That is almost the absolute worst-case scenario. To take care of the engine, you need to get the oil temperature high enough to boil off any moisture, and keep it there for probably 20min or more. You're barely getting the water up to temp in 10-15min....that can actually cause condensation when you shut down and everything cools off that little bit.
Ask your local fire dept. if they start their diesels and run them everyday, ask your local Coast Guard Station if they start their boats and warm and check them everyday, if you want it to run when you need it you'll do start ups and checks. No engine ever wore out from start ups. It's about keeping it reliable when you need it, not crossing your fingers. My guess the guy who is concerned and starts his equipment and does checks will have his equipment much longer then the guy who looks for the key once a year. HS
You ever wear out a diesel engine from start ups? I think that's a theoretic risk, sounds good, must be true, in reality it's not an issue. My experience would say putting engine under load before warm and high RPM before warm up might be way more harmful, and improperly breaking in engine might shorten life significantly. HSUp to 75% of engine wear occurs during warm up.
So your answer is no. HSGo argue with the engineers at Castrol if you don't believe me.
Nice. I sure would appreciate not feeding every day.
I've been thinking about not having to run my tractor every day. I have enough pastures that I could set enough hay out for a week (or more), a day worth in each pasture and just move the cattle every day. I worry about not getting my tractor up to temp only using it about 45 minutes each day to feed.
Sounds logical but in reality your engine doesn't wear out from starts. The more you run it the more reliable it'll be, sitting is the issue, start it run it.... HSEngines experience very significant amount of wear at startup. Much of it has to do with metal to metal contact while the engine is at rest. Once moving and under proper lube, the metal parts are separated by a film of oil when running. In addition, among other things is that the parts are designed to be at the correct size after expansion to operating temperature.
I guess you're replying to my last post. I read every post and not everyone agreed. Taking everything into consideration about my particular circumstances, I've decided what is best for my situation.
Thanks for all the input!
