Do you replace antifreeze?
   / Do you replace antifreeze? #11
On diesels it is important to change the antifreeze. Antifreeze is "charged" for diesels. It is important to use the specific antifreeze for your tractor. I would change it according to mfg. recommendations and use what they recommend. We usually use fleetguard. It's recommended for most tractors and diesel pickups.
I know you have an older diesel pickup and it's extremely important for that diesel. Those are really prone to cavitation.
I do have the older Ford pickup and buy the little bottles at Ford to dump in to eliminate cavitation but will consider getting many gallons of the Fleet Guard type I have seen at my nearby NAPA. My Kubota manual simply says to use clean water and anti-freeze, LLC (long life coolant) ethylene glycol. It mentiones to never exceed 50% anti-freeze. Now the question is, do I use Glacier melted water or perhaps the French stuff like Perrier. I think I'll stick with the US stuff. /forums/images/graemlins/smirk.gif
   / Do you replace antifreeze? #13
I replace it every 2-years with a coolant that conforms to GM 6038M, ASTM D-4985, ASTM D-6210 and TMC RP 329 Type A requirements.
Never had a problem since 1993.
   / Do you replace antifreeze? #14
moon-
From what I was told by a Ford dealership owner was that Ford copied the manuals for the international engine; but, Ford did not know about SCA and International has the coolant filters that has SCA in them. So no one added the SCA and got leaks in there wet-liners.
   / Do you replace antifreeze? #15
<font color="red">Now the question is, do I use Glacier melted water or perhaps the French stuff like Perrier. </font>
/forums/images/graemlins/wink.gif I mix mine 50-50 with distilled water.
   / Do you replace antifreeze? #16
I buy the 50/50 mix right off the shelf. Gerard
   / Do you replace antifreeze? #17
I mix 50% anti-freeze and 50% RO/DI water. I found that Distilled water is very high in TDS (bad bad).
Oh Mike, please don't tell me your using that RO/DI stuff, it has now found to be very, very bad. The surgeon general says so. I would not use it in a cheap Briggs and Stratton liquid cooled lawnmower engine that you get free with an oil change at a Ted Kennedy Bourbon free for all. As much of an advocate of synthetic oil, I am surprised you would use such an inferior H2O supplement. You really need to start getting your antifrezze analyzed. Pay particular attention to the Bs number, typically, its quite high. /forums/images/graemlins/grin.gif
Yhawza! BTW,YKIAJK, R?
   / Do you replace antifreeze? #19
<font color="blue"> Ns .100%, Bs 100%, Nn .01, Ir .023, Gg .016, Pp 4, Vr 19, xYz 2, WeWe, none detected, PePe, none detected. Poo, 6%. </font>
Looks like the concentration of some of these impurities is increasing. /forums/images/graemlins/crazy.gif
   / Do you replace antifreeze? #20
</font><font color="blue" class="small">( have many more numbers if you want them.
I believe you've covered all the pertinent categories. I laughed out loud when I read this )</font>
/forums/images/graemlins/grin.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/wink.gif I just narrowly avoided an iced tea 'spraying' incedent.. thanks.. I needed a good chuckle!!!
Soundguy
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
19200 (A50324)
19200 (A50324)
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
