Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Truck is still dead after a day of fussing with it.
We checked the numbers on all the sockets in the fuse box and the fuse relay is reading one 'prong' at 12 and the other at 6 - all the other fuses are reading properly at 12.
Went and got at the local parts store a check engine code reader and it only gave an error message that it wouldn't speak to the computer and read the codes. So even tho it seems like there is a code dinging across the dash, no clue what it is. (chimes three times, then the gas light comes on and the check engine light --- all come on a few seconds after the engine is turned "on" (but not on as in engine rotating).
Per suggestion we sprayed lightly ether/starter fluid into the air intake while 'rotating' the engine. It did attempt to start up, but choked immediately back out did not stay running. This is the puzzling part what would be causing it to choke back out - don't know if it's an electrical issue at this point or a gas pumps issue.
Currently testing all the grounds along the frame and will report back findings.
Any suggestions appreciated as time is running out have to use it next week...
I am sure its electrical some how. It may be the electrics are not allowing it to get fuel but its time to have it towed to the dealer. It should run on starting fluid. All a diesel needs to run is the engine rotating and fuel, which you had. Get it to the dealer before you end up costing yourself more money.
Chris
