Does 1200 watt block heater sound correct?
   / Does 1200 watt block heater sound correct? #11
John_Mc said:
Where did you find one of those?
John Mc
Do an eBay search for "remote control outlet" - several to choose from. Mine is like eBay item 310010521357 - works fine at a range of 75-100 feet. I plug in a small light too so I can tell if it's on. Take care, Dick B
   / Does 1200 watt block heater sound correct? #12
crazyal-
Just don't put it under things that drip. If you cannot avoid this, use a metal plate (pie plate or other) to act as a umbrella.
The ones I have are 1500 watt and are around $15 during the season and drop to under $10 at the end of winter.
   / Does 1200 watt block heater sound correct? #13
I use a timer to turn mine on when I need it. You don't need to run it 24/7 half hour before you use it is plenty. Unless it goes sub zero.
   / Does 1200 watt block heater sound correct? #14
HJT said:
I have a 2007 BX2350. Motor is 54 ci. Dealer installed a 1200 watt block heater on it. I asked him about it being so big and he said they installed that size on all Kubota's. I would think it would have a meltdown with that big a heater. Will only plug in for hour or so as needed, not plug in all the time. What size are your heaters? hjt
I'd do a little more research and try to find out what type of heater it is, as others mentioned (inside or outside the block). Either way, 1200 watts seems huge for such a small motor.
My block heater for my 7.3L (444 cu in) is 1100 watts, and heats everything up enough for an easy start in 2-3 hours. I'm quite certain the little block heater on my 24hp sub compact was no where near 1100 watts, and would heat that little block up in 15-30 minutes.
   / Does 1200 watt block heater sound correct? #16
On a 2350 with a 1200 watt heater, I would run no more than 30 min.
   / Does 1200 watt block heater sound correct? #17
I dunno. It gets cold here. Sometimes -20. After an hour my 2230 is warm on the top of the engine! You can actually hear the liquid inside churning. I think my 'Bota likes it more than me when its that cold!:D :D
No cake. No song.
   / Does 1200 watt block heater sound correct? #18
Been thinking. That's bad!:confused: With a 1200 watt block heater you can make breakfast on the hood, eat and then your ready to go till lunch.:D :D :D
   / Does 1200 watt block heater sound correct? #19
Mine is the lower radiator hose type and it's 750 watt. 30 minutes is ample time for it to warm the engine and it starts fine.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
