Does a propane tank absorb propane?
/ Does a propane tank absorb propane? #41
Set it on a scale and after a runout you'll know what weights you will be looking to refill at.
I thought about that, but it's a bit of a hassle to say the least, I've seen something on grills where the tank is on a beam or something that allows it to float upwards as it empties, as an indicator
Or contact your propane company for a gauge. There's one on my 400.
Thanks
You might also be able to tell by the frost on the tank during heavy usage. This may/may not happen.:)
I've been looking, but I guess the atmospheric conditions have to be just right, cause except for the first day I haven't seen the frost again.
Pour some hot water on the tank and feel it where it's still cold that is the propane level.
Interesting, have to try it. Does the effective level of propane, go right to or close to the bottom.
JB
/ Does a propane tank absorb propane? #42
The effective level wiil go down to the point there is not enough pressure to feed the flame. Just say empty.:thumbsup:
/ Does a propane tank absorb propane? #43
But how does that equate to the frost line on the tank, does it go right to the bottom?
JB
You should be heading for a refill at the 1/4 tank line anyway... at least that's what I do. I never want to experience the "Oh crap, I'm out." effect. Of course, if you're exchanging instead of filling, that won't work. You'd be giving gas away. The other recourse is to get a second tank for a reserve, and when the first one runs out, you put the other one on and go do the exchange.
Ian
/ Does a propane tank absorb propane? #45
As the tank goes empty the frost line may dissapear as there is no latent heat of evaporation.:)
/ Does a propane tank absorb propane? #46
Years ago (many ) Ford had a tank leaking problem ( No not the Falcon.) I brazed up a few of them. Drain out the gasoline, a little water flush, Then piped in the exhaust from a running auto. Never had a problem or fire. Had to wire bush under coating on some of them.
/ Does a propane tank absorb propane? #47
I believe every propane tank that you take away to fill has the weight stamped on it. you can get a manifold that will change the tanks automatically when one is empty and raise a flag as to which bottle it is using.
/ Does a propane tank absorb propane? #48
You should have two stage regulator. The pressure in the inside line should be very low. I kind of vaguelly remeber it should be 11" WC.
/ Does a propane tank absorb propane? #49
Exhaust gases can be combustible at certain air ratios. They do not do the job for proper purging.:)
/ Does a propane tank absorb propane? #50
You can buy propane gauges for your BBQ tank. They will also fit a 100lb tank, BUT they stay at the same presure reading until ALL the liquid propane is gone, then they go to empty in a few minutes.
I used an OLD (40yrs)20lb tank as one of my air tanks (90psi) for many years. The bottom finally pinholed so I made it into an ash bucket.(plasma cutter) I learned that the OLD tanks seemed thicker than the newer ones, and yes, they are bare steel inside...
I've cut many newer tanks after removing valve and leaving upside down in the sun for a few days, or filling with water, draining and then cutting.
Always get more nervous cutting up old fuel oil(?) tanks or making burning barrels out of 45gallon drums.
/ Does a propane tank absorb propane? #51
I needed to scrap a bunch of grill cylinders this last summer. The junk yard said they had to have the valves removed and a few holes drilled in the tank. My 30-30 did a fine job with the holes and the sledge hammer removed the valves. Nothing exciting happened when shooting the holes.
Dan
/ Does a propane tank absorb propane? #52
Dan[/QUOTE]
I had some young girls over who wanted to try shooting a 22. Also had a bunch of empty 1lb propane bottles that they wouldn't take at the dump so it was a perfect match.
Turned out one bottle was still pretty full. The jumping and spinning bottle got a laugh out of everyone,( no flames or loud noises of course)
/ Does a propane tank absorb propane? #53
Dan
Turned out one bottle was still pretty full. The jumping and spinning bottle got a laugh out of everyone,( no flames or loud noises of course)[/QUOTE]
Next time set a lit flare next to the tanks.
E\S
/ Does a propane tank absorb propane? #54
E\S[/QUOTE]
Now thats just good attempts at havin a great time.:thumbsup:
Cuz everyone loves fireworks shows:D
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
2020 JOHN DEERE SUV590M S4 GATOR (A60430)
2020 JOHN DEERE...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
SKID STEER LAND LEVELER (A60430)
SKID STEER LAND...
PALLET OF TRAILER JACKS (A60430)
PALLET OF TRAILER...
2010 BENSON/WABASH ALUMINIUM FLATBED (A59905)
2010 BENSON/WABASH...
