Does anyone have the installation instructions for a WR Long 3rd function installation for a 2665?
   / Does anyone have the installation instructions for a WR Long 3rd function installation for a 2665? #1
OldTrix
none
I'm chasing down a couple quirks in my FEL, wanted to double check the hose setup. The WR Long website offers little help.
   / Does anyone have the installation instructions for a WR Long 3rd function installation for a 2665? #2
I wish I could know if it's similar to my 3016....it was simple.
the hose routing is straightforward, was just looking for some confirmation on the loader valve ports
   / Does anyone have the installation instructions for a WR Long 3rd function installation for a 2665? #4
Do you have both the W R Long troubleshooting guide and the 3rd function flow diagram? Not sure what more you would need.
I have nothing but what I've found on the WR long site. Their instruction vid uses a kubota, so not much help. I'll take a look round again for a troubleshooting guide on their site.
   / Does anyone have the installation instructions for a WR Long 3rd function installation for a 2665? #6
  • W R Long 3rd function Hyd DO3B Flow Diagram.pdf
  • W R Long 3rd function Trouble-Shooting-Guide.pdf
This is helpful. I have a backhoe on my tractor, but I don't think the return line from the 3rd function connects directly to the backhoe, if at all. I have a rear remote that activated by pushing the cab lever all the way forward to power the hoe when it's attached.
I'll have to trace things out. The FEL works, but it has some weird behavior, like a huge air bubble is trapped in the system somewhere. I've run it through various full travel exercises, but it still is a bit "rubbery" when trying to use it.
I'm interested in chasing the 3rd function routing to make sure it's correctly installed. I bought the tractor with about 300 hours on it and everything seemed to work fine when checking it out, but it's not until you give it some real work do the issues appear. not a biggie, but definitely not the same as my 2655. That FEL was solid.
Deere 331G (A53317)
Deere 331G (A53317)
208316 (A58375)
208316 (A58375)
iDrive TDS-2010H...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
43024 (A59228)
43024 (A59228)
1459 (A57192)
1459 (A57192)
