Does Kubota offer front weights for ZD12/11 / ZD1511 ?
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I borrowed this pic from internet.
These looks homemade ?
I can slide my seat all the way forward & hang my boots out over front axle & it makes a Huge Difference climbing my steep banks here on the farm.
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #2
I've never seen any. It would be easy to make something if you could get your hands on some elevator weights. I don't battle the issues you have on this dead flat land I have.
Anybody out there fabbed up some front axle weights ?
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #4
Kubota offers weight brackets for when the mower is equipped with a grass catcher. I do not know what catcher fits your mower, but for the GCK72H the left bracket is K6031-21812 and the right is K6031-21822. Then you set suitcase weights on them to weight the mower down. Please note that if your mowing sideways on a hill the extra weights will make it harder to keep the front from sliding down.
Thanks @Sportsman762
That looks like exactly what I’m after.
Do you have part # for weights ?
And what do they weigh ?
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #7
I was unable to determine the part number for the weights.
Front weight bracket for one side of front axle.
G8103 25lb Suitcase Weight
Pic borrowed from InnerWeb
I’ll get an assembled pic next week when weights comes in.
I’m not running a rear grass catcher.
I need to keep front wheels on the ground mowing up really steep banks around my farm.
This isn’t subdivision lots lol
I got front axle weight brackets installed & still waiting on suitcase weights
I hadn’t had time to wash the mower yet lol
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #11
I made some changes to my ZD326 backup mower for mowing banks, and front weights would be a good addition.
I spread the rear wheels out with spacers and have filled ag style tires. Going up hill the unintended consequence of the great traction is the front end coming up very quickly.
If you don't mind my asking... What was the total cost of your brackets / weights?
The brackets & all hardware was $380 with shipping.
I’m not real sure on the 25lb suitcase weight yet as they haven’t came in.
Id guess the brackets weighs 20lbs per side with bolts & pins. So that’ll help too.
I have my rears fluid filled too & it makes a HUGE DIFFERENCE in Traction but it does rob HP climbing hills.
It Doesn’t spin near as bad.
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #13
Thanks for posting the follow up. Let us know how it does for you once you get the weights in!
Finally got around to adding 2 suitcase weights.
It Helped but I need 2 more which I have 6, to keep front end on the ground while mowing my steep bank.
Each side will accept 3.
With 2 weights I still had to slide the seat all the way forward on the steeper areas so I’ll be adding 2 more weights.
It Rides So much better on my rough farm ground now.
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #15
You mean the weight take away deck bounce?
It made it tamer feeling keeping the front tires planted on the ground hitting holes making deck bounce.
I don’t go so fast to make the heavy 72 deck bounce much tho.
I know all my rough spots as I’ve been mowing here since 1996 :LOL:
4 weights today : mowed 4hrs on rolling hills. It Did great.
I’ll put it back on the steep bank in a few days.
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #18
That's pretty slick. My property couldn't be any flatter than it is so weights and fluid filled tires are not a thing for me.
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #19
I might try that. Do the weights “clang” a lot? Any drawbacks?
Wonder if they hasten the demise of the front axle pivot bearing?
Definitely have to remove weights to clean deck???
   / Does Kubota offer front weights for ZD12/11 / ZD1511 ? #20
I'm surprised they aren't drilled for a through bolt. You could always wrap a bungee around them. They appear to be pretty tight though.
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
