DR three point log splitter
/ DR three point log splitter #1
buckyburrows
MA
JD 790
I have a JD 790 compact. 30 hp Yanmar. Front end loader. I want to use a log splitter that uses the tractors hydraulic pump. Does anyone know if I can hook up some quick disconnect fittings on the rear lift. The front end loader is an open center.
/ DR three point log splitter #2
I think you are going to need the Power Beyond kit to do that. The bigger issue may be the flow rate of the hydraulic pump on the 790. It might be too slow to allow you to operate the splitter at a reasonable pace.
/ DR three point log splitter #3
You could use 2 outlets from you're loader to run it but then you couldn't use 1 function of it. I have run a 3pt splitter with my 5103 Deere and it's rated at 11 gal per min to the outlets. I think you're 790 would be much slower.
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
02GER CHICKET HOUSER 240' (A62131)
02GER CHICKET...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
RoadTec RP190 (A63118)
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
