Draft Control on Kubota GrandL series
   / Draft Control on Kubota GrandL series #21
Draft control is available as an add on kit, depending on your model. You can add it yourself if you know what you are doing. I added on to my L3300, bought the kit used from a dealer who took it off another machine for around $300. I think it was about $600 new.
</font><font color="blue" class="small">( Draft control is available as an add on kit, depending on your model. You can add it yourself if you know what you are doing. I added on to my L3300, bought the kit used from a dealer who took it off another machine for around $300. I think it was about $600 new.
)</font>
What are you using the draft control for? What kind of implements? Hard to install?
Bob
   / Draft Control on Kubota GrandL series #23
Thanks Bob and others,
Why would I need draft control? If I use a plow the manual gives you the connection to the tractor with and without draft control. So my plow should work with or without draft control. But just curious before I tear something up. I see in the manual that draft control keeps the implement following the ground to a certain depth. Without it I assume that the implement will dig as deep as you have it set. Can someone clarify this for me. Thanks to all.
JIM4 /forums/images/graemlins/cool.gif
   / Draft Control on Kubota GrandL series #24
</font><font color="blue" class="small">( Thanks Bob and others,
JIM4 /forums/images/graemlins/cool.gif )</font>
You don't need draft control. You can sense when the plow is under a greater load (greater draft) and lift it out of the ground. With a lot of plowing, draft control does it for you. One less thing to worry about.
Flatbed Trailer (A51694)
Flatbed Trailer...
New/Unused 250 Traffic Cones (A54865)
New/Unused 250...
2021 BOBCAT T740 SKID STEER (A52706)
2021 BOBCAT T740...
Hyster 80 Forklift (A54865)
Hyster 80 Forklift...
2020 Bobcat T595 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T595...
New/Unused 20x30 All Steel Carport (A54865)
New/Unused 20x30...
