Draft Control on Kubota GrandL series
   / Draft Control on Kubota GrandL series #21
Draft control is available as an add on kit, depending on your model. You can add it yourself if you know what you are doing. I added on to my L3300, bought the kit used from a dealer who took it off another machine for around $300. I think it was about $600 new.
</font><font color="blue" class="small">( Draft control is available as an add on kit, depending on your model. You can add it yourself if you know what you are doing. I added on to my L3300, bought the kit used from a dealer who took it off another machine for around $300. I think it was about $600 new.
)</font>
What are you using the draft control for? What kind of implements? Hard to install?
Bob
   / Draft Control on Kubota GrandL series #23
Thanks Bob and others,
Why would I need draft control? If I use a plow the manual gives you the connection to the tractor with and without draft control. So my plow should work with or without draft control. But just curious before I tear something up. I see in the manual that draft control keeps the implement following the ground to a certain depth. Without it I assume that the implement will dig as deep as you have it set. Can someone clarify this for me. Thanks to all.
JIM4 /forums/images/graemlins/cool.gif
   / Draft Control on Kubota GrandL series #24
</font><font color="blue" class="small">( Thanks Bob and others,
JIM4 /forums/images/graemlins/cool.gif )</font>
You don't need draft control. You can sense when the plow is under a greater load (greater draft) and lift it out of the ground. With a lot of plowing, draft control does it for you. One less thing to worry about.
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2016 FREIGHTLINER CASCADIA SLEEPER (A56129)
2016 FREIGHTLINER...
New/Unused Root Rake for CFG Mini Excavator (A54865)
New/Unused Root...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
