blueriver
Super Member
- Joined
- Oct 4, 2007
- Messages
- 5,012
- Location
- S.E.Oklahoma
- Tractor
- JD 5520 Montana 4340 Farmall Super A Montana 5720C
blue river can you load on a 6x16 tag trailer with your grapple
I have not measured the trailers that I have loaded. I can tell you that I have loaded bumper pull trailers with the siderails ... when I do that I put the first layer on from the back. The grapple just fits between the rails ... set the first 10 just in the trailer and then with the next 10 push the first ones to the front of the trailer ... if the trailer is not long enough for the second set some of the bales just go on the ground and I have the customer stack those off to the side (which I grapple later) Then the rest of the load I load from the side.
With the 10 bale grapple you are able to tie the bales together... let me try to explain that.
With the 10 bale you will have 8 bales all the same direction and the last two across the end ... next layer put it the other direction tieing the load together.
