Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #1
brenth561
SPRINGFIELD
Kubota L3901HST
Need help figuring out which would be these option for my New Holland TC18. I am wanting to get an attachment to pull our boat short distances in and out of the flat sloped garage and then also have a rear option to pull small logs and trees. I also plan on purchasing the Harbor Freight Quick Connect.
Which option would provide the most benefit in the long run?
1. Draw Bar with hitch stabilizer such as the EZmover approx $80
2. Titan attachments 3 point hitch with pull ring $109
Titan also makes this one so I figured I could just drill some holes in it similar to the draw bar to add additional hooks but they said it may compromise its strength.
I figure with the draw bar I could add additional hooks and D-rings to it and also use it with other attachments I may require in the future.
or
I could just get a hitch with a D-ring or hook
I looked at that one but I really want one with a 2" hitch receiver.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #4
Do you want it quick hitch compatible?
I got one at Family Farm & Home for about $150. Probably a King Kutter brand.
Quick hitch compatible and it'll do goose neck trailers as well (not that I have one, but maybe one day.......).
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #5
Any of the options will work just fine for your tractor.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #6
And yes, you want 2" receiver capability.
Yes I want it to be quick hitch compatible. I believe both of the Titan triangle type ones are.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #8
The ones you pictured? I don't believe they are.
Usually, the top link must be unobstructed from below.
The top link is on the tab sticking out the back (front?).
http://tinyurl.com/gnx7r7t
Per amazon reviews it will fit the quick hitch but you have to manually put the top link pin in.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #10
I have the Titan triangle one and use it most of the time for exactly the same purpose as yours. And carrying a cargo tray. It is bullet proof.
However, I just got a Harbor Freight Quick hitch. I plan on welding a receiver hitch tube under the center of the top hook mount to keep that versatility and gain a quick hitch. The receiver tube cost me 8.95 at the local farm supply. Still have to get the hooks or a D ring to weld on at same time for chains/straps.
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
