2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,264
I'm not too clear---is this repair going to be made at a customer's place or at your place? If you run into trouble fixing it at your place, you can at least button it up where you are and start back on it at your convenience more easily at your place than at the customer's.
Get some empty five gallon buckets or something to catch that oil and some plastic sheet or something clean you can lay that rod assembly on when you get it out. Somebody else may have a better idea about draining as much oil as can be before you pull that rod, but the only way I know is to disconnect the hoses and try to manually pump the rod. Then the oil is going to shoot everywhere. I guess if you had some other hoses to connect to the ports, then you could have better control where the oil ends up.
One more thought. Get some plugs and caps you can use to plug up your lines and the cylinder when you take it off. Then you can take the cylinder someplace to your convenience to work on without it leaking everywhere in the process.
