Drive over gate
   / Drive over gate #1
bigtater
Southeast, TN
bota 5700
I'm looking for the name of the gates that you can drive over but keep livestock from crossing. I've seen some made of metal but most are made of concrete.
Thanks
   / Drive over gate #2
Thanks
Are you talking about a cattle guard?
   / Drive over gate #3
Thanks
In Oklahoma and Texas, at least, we only knew them as "cattle guards", but on one trip to Alaska, at a place we were going to spend the night in the RVs in Canada, there were signs along the road showing distance to a "Texas Gate" ahead and I didn't know what that was until we got there and saw it was just a cattle guard.:D
   / Drive over gate
Thats it. Does anyone have plans for one. They look easy to make but I'd hate to screw it up.
   / Drive over gate #5
It looks easy enough to make. Just check the size of the gaps they use and make yours like that. You should also get an idea of the metal thickness and reinforcement used so you can drive over it. If you have that information, from what I've seen, I doubt there's any big secrets in making one?
Good luck and post pictures for us.
   / Drive over gate
Metal thickness is what I'm having worries about. Searching the net the cheaper one's go for around 800. I've got some h beam, I just need the tubing for the top.
   / Drive over gate #7
bigtater said:
Metal thickness is what I'm having worries about. Searching the net the cheaper one's go for around 800. I've some h beam, I just need the tubing for the top.
You should be able to find some old drill stem at a reasonable price.
   / Drive over gate #8
Most of our cattle guards around here are made completely from drill stem. I try to design mine so I can remove the guard from time to time and clean out the hole underneath. I have seen some where wash filled up the hole underneath, eventually buried the pipe and the cattle came and went at will.
   / Drive over gate #9
bigtater said:
I'm looking for the name of the gates that you can drive over but keep livestock from crossing. Thanks
I knew that I was a city boy, now living in the country. But now I must also be a northern boy (although, Alaska is a still little north of me). Am I the only one who has not seen or heard of a cattle gate before? :eek: How does it work? Is it installed, laying flat, into an opening in a fence? Why won't cattle cross it? What about horses? :confused:
   / Drive over gate #10
Rusty,
It is my understanding that the guard works with the rolling pipes across the top that lets the foot of the animal through the hole in the bottom. Eventually all four feet will be stuck in the hole because the pipes on top roll and spin, so I think any sized foot will get stuck.
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
LEE BOY 8520B ASPHALT PAVER (A60429)
LEE BOY 8520B...
JCB 2145 (A47477)
JCB 2145 (A47477)
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
