Driving a well point?
   / Driving a well point?
I've jetted wells for years, the only way to go!
I use a 2" trash pump hooked to large water tank.
I'm really liking this jetting idea. I've been looking for an excuse to buy a trash pump...:D
If you've never tried to unsweat a copper pipe filled with water, let me save you the trouble...it doesn't work.
I was only talking about if there was a fire...where plastic water pipes could melt...I'm just guessing most of the copper joints would burst if your house was burning, although that seems like a good thing to me. :D
I will have the water tested if I find it...and if it's clean, I'll probably drink it in preference to our fancy tap water. It's pumped from one of the most polluted rivers in the country, downstream from at least 2 sewage discharges and an old leaching landfill...*sigh*
   / Driving a well point? #32
I never realized there was a name for it but I once installed a well using a pressure washer. It was a little messy but is sure beat trying to drive a pipe by hand. I did the first few feet with a hose and then turned to the PW with the pressure turned down.
   / Driving a well point? #33
You could build yourself a well drilling outfit that can go down 300 feet or so. My Grandfather and Father drilled wells with one many years ago. Took about four days or so.:D
What kind of pump can you use with a well that's drilled to this kind of depth? I would assume that something of this depth needs a small type of mechanical lifting arrangement rather than an electrical pump? For that matter, a well driven with a point beyond a certain point, simply because of the diameter of the pipe used, also cannot accommodate a submersible pump and jet pumps don't work either?
Our place once had a hand-dug well to 90 feet with 10 feet of standing water in it. Tragically, a baby fell into it some years back and it was then covered and is now used as a cesspool. But we still have water supply problems here so I'm also researching what route to go.
   / Driving a well point? #34
Submersible well pump.
Amazon.com: submersible well US Home Improvement
The old well - I wouldn't be too keen on on putting sewage deep in the aquifer. Think about reclaiming it for irrigation. A submersible pump still allows the use of a solid cap.
   / Driving a well point? #35
[What kind of pump can you use with a well that's drilled to this kind of depth?/QUOTE]
These wells were usually cased with 6 inch pipe. At that time most used a sucker rod PD pump but when the hydro came they would add a pumpjack and electric motor instead of the windmill or gasoline engine. Lots worked on hand power too.:D
Then they installed the downhole centrifugals or jet pumps.:thumbsup:
   / Driving a well point? #36
I should have been clearer about my question, since I was assuming Egon was talking about sinking a well with a small diameter pipe, which he kindly cleared up for me with his post. Your link, Brad, shows a submersible pump with a 4" diameter, easily fitting into typical "big-rig" drilled well with a typical 6" casing.
Fortunately, the old well doesn't take on any sewage, but acts more like a dry well for draining the excess rain runoff from the yard.
So here's what I'm really interested in learning, and hadn't clearly seen yet in all of my "googling;" is it possible to go down, say, 100 feet with one of the simpler methods described here on this thread AND end up with a casing large enough for a submersible pump? For most of what I've seen for a do-it-yourselfer like me, I have assumed (and we all can now see how well that's worked out for me, eh?) is that I'd end up with a smaller diameter casing/pipe that precluded an electricity driven submersible pump. Actually, I say do-it-yourself pretty casually; I'll most likely have a few of my regular laborers (well-paid at the equivalent of $2.50/day) doing all of the heavy, labor-intensive work, but still avoid a costly drill rig I hope!
Egon, your method seems to me to be the only one that can give a casing large enough for a submersible pump at the depth needed for situations like mine, then. All I gotta do is study that sketch you posted a leeetle bit harder... any chances you could enhance it some? Thanks.
   / Driving a well point? #37
A packer assembly will use the outside pipe and a drop pipe in the center to a packing assembly. Works like a two pipe jet system.
Illegal in some if not most states.
   / Driving a well point? #38
Thanks Bill Barrett! Your information about a packer assembly opens up a whole new avenue of thinking about this for me. I found an excellent page HERE from Gould Pumps that shows the packer assembly used with either a 2" or 3" casing, the 2" of course being the more do-able solution. So now my next challenge is to find out what's available here in my area (Republic of the Philippines) for this type of assembly.
   / Driving a well point? #39
This thread got me psyched to get my own irrigation well put in. We've had a severe drought for a year, so I have to get it in gear.
Picked up a shallow well 1/2 hp pump and 10 gallon tank for $90. off Craigs today. I'll work on the drive point, pipe, drive couplings, etc this week.
What do you guys think about using a pressure washer nozzle like this:
Jetter/Drain Cleaning Stainless Steel Sewer Jetting Nozzles 17.0825 17.0827 17.0828 17.0829 17.0842
It's designed to clean sewer lines. If I used a 2" PVC casing, and ran one of those down a hose in the center, can I expect to push the PVC in easily? (until I hit a rock...)
The last time I used my pressure washer it was to move a dump truck of gravel from here to there. I used the 0 degree nozzle and just blasted it all where I wanted it! I was amazed at what a good "excavation" tool it made.
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
