Dual operation of 3-point hitch and log splitter (JD 4600)
   / Dual operation of 3-point hitch and log splitter (JD 4600) #11
I don't know enough about valves to be able to tell and open center from closed center. Some valves can be converted so they look the same outside. I did a little research. Wallenstein valves apparently are not convertible. They supply the one valve or the other. From the factory a closed center splitter has a C at the end of the model number (i.e. WX310C). Of course, a dealer can switch the valve if needed, so the serial number won't tell you for sure.
Maybe someone else here knows how to tell an open center from a closed center valve.
   / Dual operation of 3-point hitch and log splitter (JD 4600) #12
KennyD - Is the backhoe Power Beyond different from the one I have on my 2320? My 3 point hitch works with the Power Beyond in operation.
   / Dual operation of 3-point hitch and log splitter (JD 4600) #13
The power beyond is designed to disable the 3PH for when your using a backhoe, the return line goes directly to the tank bypassing the 3PH/rockshaft valve. You'll have to OUT of plumb the splitter using the other fitting-the one that's used when nothing is attached.
+1 agreed
   / Dual operation of 3-point hitch and log splitter (JD 4600) #14
Short answer: Yes.
The larger JD tractors are different in that they have one feed, and two returns-one of which bypasses the rockshaft valve. They are clearly shown in JDParts, sorry I can't post a picture from there right now.
New to the forum but have accessed periodically and found it to be a great source! I have a Wallenstein 3-point hitch log splitter which I believe is the WX310 or equivalent as I purchased it in ~2004. The tractor is a ~2000 or 2001 JD 4600 (43 HP). If possible I would like to be able to have the log splitter hooked up to the tractor hydraulics and still be able to operated the 3-point hitch without switching hoses around. That way when repositioning the tractor around the pile of wood blocks I can raise and lower the splitter as needed without switching hoses constantly. This question has likely been discussed in a thread already so if someone could point me in the right direction it would be much appreciated! Thanks.
Thanks for all the help guys, I appreciate the advice!
Ian
   / Dual operation of 3-point hitch and log splitter (JD 4600) #16
I made my own power beyond for a JD 4300. Simply replaced the steel line from loader control valve to left side of tractor where it fed into rockshaft valve. Put male and female couplers in the middle of new hose. I am currently running a JD 48 backhoe off of this set up and it seems to be ok. I think that if you where going to put heavy loads on your 3 pt while PB is hooked to supply other implement,you would need to have a PB valve on implement .
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
