Dump truck project (Mirror Question)
   / Dump truck project (Mirror Question) #11
Thanks I will make a trip to the bone yard and see what I can find. The after market ones I saw were around 400 for a set they will make a round trip right back to the store if I end up paying that kind of money and they vibrate so bad I cant see out of them.
The new color will be Kubota Orange seems only fitting since this will be my L-39 toter.
Kubota Orange? :eek:
How about a nice Summit white? :)
Sorry to get off topic, but wouldn't it be awesome if GM brought back the 3500HD with 4x4 and the duramax/ally combo?
   / Dump truck project (Mirror Question) #12
Very strange. When I go to GMC.com, and select build your own, to build a 3500HD 4wd, when I choose the Duramax engine it automatically selects the Allison transmission. If I choose the gas engine, then choose the Allison, my engine selection is automatically switched to the Duramax. Apparently, the Allison is only available with the Duramax. So I don't understand your comment.
On edit: Looking at the specs, the Duramax/Allison combo is only available with a 3.73 axle ratio. The 4.10 ratio is available ony with the gas engine; probably a fuel economy issue.
   / Dump truck project (Mirror Question) #13
Ahh, I see, you must be a younger fella. About 10 years ago, GM built a truck called the "3500HD". It was an early variant of the Ford F-450/550 trucks. It was a 15,000 GVWR chassis that rode on 19.5" rims & tires. It was only available in 4x2 (although some were sent to Monroe and converted t 4x4) and was discontinued just before the duramax or Allison was available in 2001.
Now GM has the 4500/5500 series, but the old 3500HD was a more compact truck that used a pickup body on a heavier chassis.
   / Dump truck project (Mirror Question) #14
You can find them fairly cheap Builder, but usually there is either a probelme with the old 6.5L diesel or the transmission. That same truck with a Duramax and Allison could have dominated the market. The new 4500 and 5500 are nice but much larger.
   / Dump truck project (Mirror Question) #15
It really would have dominated. How nice a 450/550 would be with a Duramax LBZ and an Ally 6 speed? ;)
   / Dump truck project (Mirror Question) #16
i think the 4500 and 5500 are nice rides but they are just a little big 3500 is big enough for me . funny how mirror talk went to truck talk thats what is fun about tractor by net you get to talk about what ever with a bunch of guy's that do not have an attitude and are happy to share their oppinons and experiance from the field :D
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
Hydraulic rail grinder (A56436)
Hydraulic rail...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
