Earth Mover my neighbor built
   / Earth Mover my neighbor built #41
Boy, this is a good example of the problem with this website ... you're always finding new things to build that you never even thought of, or even realized you had a need for!
   / Earth Mover my neighbor built #42
I would like to build a 20hp garden tractor size scraper somthing like this.
   / Earth Mover my neighbor built #43
That is just sooo awesome !! it looks like that little tractor buries it deep into the ground, but i assume the pan sides arent that high after all so it looks like its going deeper than it is... ;)
I just have too many ongoing projects, i dont even dare to write the scraper on my wish list because i have a feeling that if i keep adding, it has to wait untill i retire.. :p
   / Earth Mover my neighbor built #44
Kansas Kid, Were are you from. That one looks very close to my DB-6 from Hoelscher Commercial Products - DB Scraper
It would be fun to set them side byb side compareision, I could really use the front part to keep lose dirt in there while hauling it.
DDT
   / Earth Mover my neighbor built #45
The little scrapers are really underrated. There is nothing you can hitch/attach to a wheeled tractor that will move more dirt as quickly as a dirt-pan.
I've used them to clean out tanks ("ponds" to the Easterners;) with great results. They can dig in a very controlled manner.......long and shallow or short and deep.....and do so with a good degree of precision. Honestly, I prefer to use them for serious earth-moving against a dozer because the amount of dirt moved and the cycle time in each 'pass' is generally better.
   / Earth Mover my neighbor built #46
Any new info regarding plans availibility???? Even sketches with critical dimensions would be worth $.MikeD74T
   / Earth Mover my neighbor built #47
My first job with mine was to build my lagon. It took 1/2 day for the dirt work. This type of job helps off set the cost at least for me. The one I have has a frost bit (that is what they call it) This does help for penatating hard ground and vegitation.
   / Earth Mover my neighbor built #48
Do you have any pictures of the dirt works at the lagoon ???
   / Earth Mover my neighbor built #49
On a scale of 1-10 this gets a 9.5. The last 0.5 will be determined by the color itis painted. Just Kidding!!
Really nice workmanship. Within 5 minutes, I decided that I need to build my own. Can you post some more construction details and pictures?
Besides using this as a pan scraper, I also have in mind using this with my mini excavator for transporting material. I am also thinking that if a small unit works well, about 4 feet wide, I may build a second unit say around 5-6 feet for a larger tractor!!
TRTom
   / Earth Mover my neighbor built #50
Here is a link to Soil-Mover. I have the RO series 1-1/2 yard (See Pg 3) that I've had for about 7 years. I used it to raise a roadway back then but haven't gotten that much use out of it since. You never know though, might come in handy some time.
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
2014 Timpte Hopper Bottom (A56435)
2014 Timpte Hopper...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1285 (A58374)
1285 (A58374)
