Earthforce Hydrostatic Help Please
   / Earthforce Hydrostatic Help Please #21
Apparently they have had multiple problems with internal components of the pump, that controls the hydrostatic drive as well as the hydraulics. It cost about $1700 to replace what mine needed replaced if that helps.
   / Earthforce Hydrostatic Help Please #22
Thanks you for your quick response I called them and left my # maybe they will call back before it is sold. ? do you like your have you had much trouble and is it worth the problems of trying to source the parts
   / Earthforce Hydrostatic Help Please #23
Are there any other issues you have run across
   / Earthforce Hydrostatic Help Please #24
I haven't had any other problems other than when the fluid would get heated up before I had it rebuilt, it wouldn't move until the unit cooled off. Rebuilding the pump fixed that issue.. It had 3 leaking cylinders when I got it and we got the cylinder rebuild kits from a local hydraulic shop in Orangeburg, SC and was able to rebuild them with no issues. So far so good. I use mine for digging stumps and trenching on the side. We don't use it too often but haven't come across any other issues.. has a Kubota engine in it, which parts are readily available if needed for it. It's a pretty simple machine, yet pretty powerful for it's size.
   / Earthforce Hydrostatic Help Please #25
Again thanks. I have 10 acres that need a lot of work need a field line for a septic system need to dig a trench for water line from the well and soooo many other things. been looking for something and ran across this earthforce and it looks like it will do the job.
   / Earthforce Hydrostatic Help Please #26
hello, the topic is still open, I recently bought a b100 bobcat, everything ok but after heating the oil I can not go with it back or forward :( does anyone know what the reason is?
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2014 Ford F-150...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
John Deere 3025E (A53317)
John Deere 3025E...
