Easy way to share transfer pump?
   / Easy way to share transfer pump?
jwstewar said:
Good one Theo. I was thinking the same thing.:D Except multiple tanks makes more sense.
Sorry (to LB) I couldn't resist. i'm usually a dead serious, no nonsense guy, but the irony drew me in like a moth to a flame.
Theo
J0be269 said:
Seriously, LB did bring up one good point. I'm assuming the tanks are residing in the bed of a truck or on a trailer most of the time. If they are pretty close to each otheryou could alway elevate one tank an inch or two higher than the other. Then come up with a way to connect the two tanks at their lowest points. This was your higher tank (without pump) would completly drain into your lower tank (with pump). Would give you the incrased capacity without the need for moving the pump.
Understood but they will be in different vehicles.
Theo
   / Easy way to share transfer pump? #13
I just unscrew the pump and change it to the other tank. I did put a QD plastic coupler on the hose ( the black banjo fittings ) his makes unscrewing the unit a lot easier. My pump has a plastic downspout the will adjust so I can use it on a 55 gal drum or the smaller transfer tank in my truck. I admit I have several pumps, both electric and hand but I do change them around depending on which one works the best ( one has a faster delivery rate ). I also haul mine on a trailer or in the truck and it does bounce a bit, so any extra connection to the pump body would have to be strong. (disclaimer; In texas it is legal to haul a tank under 105 gal. with diesel without special permits, providing it is not plumbed to the vehicle.)
AlanB said:
Are the tanks physically close to each other or is it something like a tank in your truck and a tank at the house?
In the petroleum world (that sounds wrong) but it is commonly done with Camlocks and hoses. Might need to build a little skid or something for your pump (we have one we keep on a handtruck) and then just put appropriate ends on your stuff.
I am probably spelling the name wrong, but you can look down the list here
Fuel & Energy Classifieds in Moreno Valley, Auctions, and Sales near Moreno Valley, California
and see several versions etc. of Camlocks. An industrial hose house should have them on the shelf in various sizes and configurations to meet your needs, there are also caps etc. available easily.
As above, two different trucks with one in each truck.
Theo
That is not a bad idea although I would have to replumb the filter to enable it to unscrew like that. can you elaborate on this hose coupling you use? thanks.
Theo
   / Easy way to share transfer pump? #16
Theo
Then camlock and cap the ends, and small transfer hoses and a pump on a skid.
Yep, we talked about that option. makes a lot of sense too since the pump is not needed for fill-ups. why haul that pump and hose all over creation when it is only needed back on the farm.
Theo
   / Easy way to share transfer pump? #18
I don't have the camera with me, but could probably do it tomorrow if you want to see what we did.
Not necessary but thanks for the offer. We get the concept having discussed it before including advantages and disadvantages of full remove and store concept. i'm just not ready to throw in the towel yet on the quick switchable mount idea. if we can find the right parts for that approach to work and be secure and leak tight on the truck, it would still be our first preference.
Theo
   / Easy way to share transfer pump? #20
Does your pump pull out the bottom of the pump or out the "back".
If it pulled out the bottom, you could just upsize the camlocks, say to 2", mount them verticle and it would work.
Or, you could put a 2" verticle on your tank (female) then make a 1" drop tube with a 2" male camlock outside of it. The camlock would do the support, while the drop tube would do the pickup.
That is similar to how we do tanks, with a 4" stub, then do a 2" drop through the middle.
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2003 INGERSOLL RAND SD-105DX SMOOTH DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
2020 Kinze 3505 High Speed 6/11 Planter (A55314)
2020 Kinze 3505...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A55745)
2018 KENWORTH T800...
