Effects of Trailer length
   / Effects of Trailer length #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
I'm getting ready to buy a new bumper pull PJ equipment trailer. I've used 16-18' trailers in the past that handle my 8000lb load very well. Truck pulls good without issues. Then I bought a new 20' Kaufman that has been a nightmare and pulls bad. Jerks truck and way more vibration than the Towmaster and other trailers. Now the PJ I'm looking at is a 22' so is a bit longer. So does trailer length cause more issue which is party why the Kaufman pulls worse than the 16-18' trailer? I would like to go from 20-22' but if that can potentially make things worse towing then may just stick with a 20' version. Again, keep in mind I've only towed with one 20 footer so can't really compare it to another 20' trailer. All the ones I have used are bumper pulled and deck between fenders.
Thank you
Sent from my iPhone using TractorByNet
   / Effects of Trailer length #2
It would be helpful if you provided the exact towing situation you are referencing.
Assuming the trailer is built properly, I believe it has more to do with load distribution, hitch weight percentage and the actual tow vehicle hitch, plus the tow vehicle suspension. It all works in unison.
I had a 24' inshore, IB, cuddy cabin, hard top, fishing boat on the back of my 1996 Jeep GC using an Equalizer brand weight distribution/sway control assembly. The rig was ~ 11' tall and towed beautifully up and down hills on Interstate and two lanes alike in any weather. Never a problem. Handled perfectly.
All of my smaller trailers handled well with standard bumper hitches.
I recently purchased a 20', 10.4K# Lawrimore equipment trailer and the 75 mile drive home with a standard bumper pull hitch, trailer empty, on a very windy day was a white knuckle experience when I was on the open Interstate and only calmed down to a more normal drive once I was inside the city limits where the wind had far less effect. I spent a lot of time with the trailer brake controller and could not get much above 55 MPH. I have yet to tow this trailer loaded (Jeep is not capable) to see how it pulls. But I expect loaded, with the proper tow vehicle, using the same Equalizer hitch with built-in sway control, the drive will be fine.
Jerking, bouncing and sway has a lot to do with load distribution, tow vehicle suspension (and length), tow vehicle hitch and proper load equalizing stabilizer bars (proper weight rating). Some folks can tow without a load distributing/sway control hitch in THEIR circumstances and many others require it. Take a look at most heavy towed rigs going down the road and you will see an equalizer hitch, whether it is a 3/4 ton/1 ton truck or less.
BTW: You can always ask the trailer dealer for a test pull.
My truck is a 2008 F250 diesel crew cab. Load is a Ford 4610 tractor with HD 6' bush hog. It has always been same load on all trailers and have never needed a weight equalizing hitch as all pulled fantastic except the 20' Kaufman. All trailers exact same design except for length. I have move the load around but nothing helps. I really know where it needs to be anyway but did try to move it around a bit. Nothing helps the Kaufman. After reading their reviews and going to the BBB and seeing their F rating I now feel it's the trailer but wanted to ask anyways. Thanks
   / Effects of Trailer length #4
I've always found longer trailers to be smoother to pull. I'd bet there is some sort of issue with the Kaufman unable to be easily seen.
   / Effects of Trailer length #5
And easier to backup also.
If you do not find a satisfactory answer in the coming posts, I would suggest you borrow a load equalizing/sway assy. It could just be a combination of this particular tow assembly that could now need one.
I would also measure the trailer axles to ensure they are lined up/parallel with the trailer frame. I can't imagine what else would cause this.
   / Effects of Trailer length #6
My 20 foot trailer hardly ever feels like it is behind the truck. Only when it hits a pot hole or something can you feel it behind the truck. I cant imagine what could make yours so rough to pull.
   / Effects of Trailer length #7
Also look for a bent wheel by jacking up the sides of the trailer and spinning each wheel and looking for out of true.
   / Effects of Trailer length #8
I prefer my trailer axles perpendicular to the frame. :)
Also check the hangers and equalizers to be sure they are a matched set and installed correctly.
Bruce
   / Effects of Trailer length #9
   / Effects of Trailer length #10
Being in the trailer business for 25 years I see two issues more often than not with bad towing trailers.
First is Bias tires. I will not touch them.
Second is unbalanced wheel and tire assemblies. I demand all my stuff gets spun balanced.
Chris
   / Effects of Trailer length #11
I agree with Chris. My last trailer was a 20' H&H tilt bed, Came with bias tires. It always pulled well. When I needed to replace the tires I went with new rims and radial tires with a higher rating. Best move ever. Once I mounted and balanced the tires and installed on the trailer it pulled much better.
Now I have a 22' 14K PJ tilt bed with radials. It tows great. Barely know its behind me. First thing I did when I got it home was pull the wheels off and put them on the spin balancer to check them because I didn't see any weights. Turns out they were all within 1/2 oz. of perfect.
I don't have experience with Kaufman but have heard from 2 guys that own them and they were not happy. Said the trailers bounced a lot, didn't pull straight, had hard times balancing a load. They never found out why and sold them and bought other brands.
   / Effects of Trailer length #12
The setup I posted earlier - the F150, 14k PJ, 8600lbs, radial tires, weight distributing hitch. I took that from Virginia to California. Never a hint of sway or bounce. At the speed limit pretty much all the way, including windy days in Texas and Oklahoma. As others have said, a lot depends on the entire setup and how it all works together.
Yes Kaufman trailers suck. Sure wish I would have reviewed them before I bought. They are a big local supply with great pricing. Once I bought my trailer I began calling them for help and they put me off on a local trailer repair shop. Unbelievable. I told them I would tell everyone I meet about my experience and will never buy another product from them. After this experience went online and was amazed at all the bad reviews and BBB rating. Some good reviews to of course but way to many bad ones. Total opposite with PJ and Hudson.
By the way had first tire blow out at about 1500 miles then another a few months later. Turns out the tires they used were very very cheap and had a third one with separated belts. So dumped another $700 for 5 new tires. Runs a little smoother now but still not right. All this with less than 4k miles on trailer.
Based on everyone's help here I'm going to a 22' PJ.
Thank you
   / Effects of Trailer length #15
Thank you
Does it use a standard lug pattern setup on the wheels like 5 or 6 lug?
Or does it have the Dayton Style wheels? They are another thing I will not touch along with MH axles.
Chris
Just the standard.
   / Effects of Trailer length #17
The trailer business is VERY competitive. If something is a lot cheaper than all the others they are cutting some corners somewhere.
   / Effects of Trailer length #18
Chris
Ditto on these suggestions. Even brand can make a difference as well as load rating.
   / Effects of Trailer length #19
I wonder how this one tows?
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
1990 Bayliner 19ft Trophy Center Console Boat w/ S/A 20ft Boat Trailer (A59231)
1990 Bayliner 19ft...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
