Electric Drive Motor Retrofit
   / Electric Drive Motor Retrofit #61
Anytime you convert one source of power to another, there's loss of efficiency.
I don't see how an articulated machine that currently has 4 hydraulic wheel motors could replace those wheel motors with electric wheel motors (see past posts on how the hydraulic wheel circuits currently work) in any kind of financially responsible manner. :laughing:
Articulated wheel loaders that use differentials front and rear would be more conducive to powering the drivetrain mechanically with an electric motor or two than these hydraulically propelled machines.
   / Electric Drive Motor Retrofit #62
I don稚 know. This is not a trivial exercise.
   / Electric Drive Motor Retrofit #63
Oh, I agree. However, how are you going to control turning on the steering each time you need it? Very complicated and expensive circuitry for sensing.
Put a push button on the dash and have a timer for several minutes with a buzzer warning 10 seconds prior to stopping pump. You could have a pressure switch to keep it on if there is back pressure indicating pump needed.
   / Electric Drive Motor Retrofit #66
   / Electric Drive Motor Retrofit #67
I see the proverbial one armed paper hanger here. :)
This is the simple way. How about a metal sensor that monitors a toothed wheel on the steering wheel so if it sees motion it starts the pump and then runs it for about 20 seconds. Joy stick could have a push button mounted on the knob or just wiggle the steering wheel a Little. Or just use the knob button to start the pump for 20 seconds.
   / Electric Drive Motor Retrofit #68
Yeah. A toothed gear on the steering shaft with a proximity switch would work. We used those to count pulses on the drive shaft of our printing press.
   / Electric Drive Motor Retrofit #69
S
You got me thinking. I wonder what fork lifts do.
   / Electric Drive Motor Retrofit #70
S
Many of the smaller ones use a single drive motor that pivots to turn the machine for the rear axle and the "front axle" has two unpowered wheels. The larger ones often use a single electric motor and a standard differential on the front axle.
Aaron Z
EXCAVATOR RIPPER (A58216)
EXCAVATOR RIPPER...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A58375)
UNUSED CFG...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
404 (A52709)
404 (A52709)
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
Hose Reel (A55787)
Hose Reel (A55787)
