NoTrespassing
Elite Member
I just read and didn't realize solar panels become less efficient in hot weather by as much as 25%.
Well let's see. You can get 425 watt panels that are 80"x40". Paving CA (163,696 sq mi) with these would result in 205,361,215,488 panels, which is good for 87 terawatts. Assuming you get an average of 6 solid hours per day of that through the year, that's 190,530 terawatt hours.I don’t know if this is true. On the radio today they said that to make enough power with solar panels for California 100% of the state would need to be covered with the panels.
So it would be impossible to power the state with green energy alone. California has already shut down all but one nuke plant. So they aren’t headed that way either.
So with 600,000 EVs out of the 38 million vehicles in California the power grid is already over loaded. What a mess they are making out of that state.
Do you have Smart Meters?Peak vs off-peak electric rates. That must be a feature in larger urban areas. Here - it's the same 24/7/365.
Then again one would have to factor in all the electric vehicles mandated in California, so what would their electricity demand be if all cars, trucks, tractor trailers, tractors, mowers, etc. were electric? Add to that the fact that California right now the grid is overwhelmed. You wouldn't have to cover the entire state with panels but "only" tens of thousands of acres.Well let's see. You can get 425 watt panels that are 80"x40". Paving CA (163,696 sq mi) with these would result in 205,361,215,488 panels, which is good for 87 terawatts. Assuming you get an average of 6 solid hours per day of that through the year, that's 190,530 terawatt hours.
The entire USA used 3,930 terawatt hours last year; paving California with panels would not only be enough to power California, but it would power all of the USA 48 times over. This, of course, is why lots of people say "just turn Nevada into a solar generator" because... same thing, only even clearer skies, probably... and fewer people, less farmland to cover.
OBVIOUSLY you can't cover the whole state in solar panels, but the stated claim (which suggested it in the first place) is utterly wrong.
Feel free to move the goalposts. I was merely countering the initial statement as it stands.Then again one would have to factor in all the electric vehicles mandated in California, so what would their electricity demand be if all cars, trucks, tractor trailers, tractors, mowers, etc. were electric? Add to that the fact that California right now the grid is overwhelmed. You wouldn't have to cover the entire state with panels but "only" tens of thousands of acres.
Then the green idea of lowering Earth's temperature...panels output DC with is converted to AC. How much heat would be generated by all the inverters required?
Inverter, charging station, transmission transformers, etc. The heat output would be tremendous. Tremendous!
What stories did I make up?You make up stories when I present facts.
Most people have a 5 gallon can of gasoline, people with mowers. A hurricane if my car had 1/4 tank I'd carry with me. 35 mpg would give 175 extra mile range.
As I've repeatedly said...choices...if you love electric get one, I don't and won't.
Amen, pass the biscuits please!You make up stories when I present facts.
I've got a thousand miles of diesel ready (assuming I don't siphon whatever's in the tractor) and tons of food too (and more if I decide the chickens are coming too in some form or other), but yeah, I'm not in a city. It's really inconvenient for me to do major shopping, so I buy enough for a couple months and have a very different behavior pattern from what it would be if I lived next door to a grocery store.Being prepared is a way of life, at least it is here. We have at least a years food supply. The freezers are kept full as is the pantry. We have a small inverter generator that will keep the food frozen and run the heaters if the wood stove isn't going. Everything that uses gasoline is topped off in the Fall and all my gas cans are full. It is amazing how much gas three snowmobiles hold!
There are times when we may not even leave the ol' homestead for weeks or even months at a time.
City Dwellers must listen to a different drummer...
Maybe you could move to Houston, in time for the next hurricane.Being prepared is a way of life, at least it is here. We have at least a years food supply. The freezers are kept full as is the pantry. We have a small inverter generator that will keep the food frozen and run the heaters if the wood stove isn't going. Everything that uses gasoline is topped off in the Fall and all my gas cans are full. It is amazing how much gas three snowmobiles hold!
