Electrical hazard???
/ Electrical hazard??? #21
How old is house? I agree the outlet should not be in pit. Should be above it. This circuit may be on a GFCI circuit. The GFI may be before this outlet. NEC code did not call for a GFCI breaker on a sump pump circuit till 2008. NEC now requires all outlets in an unfinished basement to be GFCI protected. This sucks as a GFCI will trip easily and you can have a flooded basement. You can get a equipment GFCI which is less prone to trips but in my opinion; all sump pumps should have a special twist lock receptical so the dedicated circuit can only be used for the sump. People kept useing sump circuits for other things, thus causing the code change.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
