Emax22 hard starting and white smoke?
   / Emax22 hard starting and white smoke? #31
your starter wont last long doing that... feel how hot it gets after you crank it over till it starts...
The tractor was purchased in 2006 and now has just over 600 hours on it, so it lasted a long time and shows no issue with starting.
   / Emax22 hard starting and white smoke? #32
You speaking from experience with the emax? I have had mine since new, when it's cold it will not start with out glow plug being cycled at least once. With out using the glow plugs it's cranks and won't start and starter takes a beating.
Use your glow plugs to start it that's what they are for....
Glow plugs are for faster starting and in your case you need them. Not all díesel engines have glow plugs, they work off the heat generated during cranking. I have a good engine setup.
   / Emax22 hard starting and white smoke? #33
There is a lot of clatter with that engine. Get your valve adjustment checked if it doesn't quiet down with the injectors serviced.
   / Emax22 hard starting and white smoke? #34
I when back and listen to the other videos and and your right about the clatter, I kept waiting on a rod to exit the engine when he got to the high rpms.
Ok so i got the injectors back and installed them. I find that the engine runs a little bit smoother and smokes slightly less at pto speed, but it still is hard to start and smokes quite a bit at startup. Not sure what else to do, but im assured that this is within normal operating specs. If i can get my hands on a diesel compression tester, i will check that, but otherwise im out of ideas.
   / Emax22 hard starting and white smoke? #36
Leadfoot, I went out 2hrs ago to blow snow with the Emax 25. The tractor is in a unheated, non insulated barn and hasn’t been started in a few weeks. Currently 15 degrees out with feels like 0 degrees. I ran the glow plugs twice then started it. A little black smoke then a little white smoke then none after that. I am no diesel guru but sounds like something is going on with yours. If you want, next time I cold start it I could try to video it. So you could see what I get.
   / Emax22 hard starting and white smoke? #37
The engines in the emax are daedong engines. I believe most of the clattering you hear is mostly at idle. And I am pretty sure a lot of it is the inside of the muffler rattling around. As once you up the rpms it pretty much goes away. Definitely not as quite as the iseki that I have.
   / Emax22 hard starting and white smoke? #38
Since I couldn't see what the rpm were when it first started here something you might try. Since diesel engine need a over rich mixture to start, try bumming the throttle up to make it have have more fuel before starting. It could be that your throttle linkage it out of adjustment making it run lean.
2011 SHOP MANIFOLD TRAILER (A58216)
2011 SHOP MANIFOLD...
6ft American Flag Metal Rooster (A57454)
6ft American Flag...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
Zero Turn Mower (A59228)
Zero Turn Mower...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58216)
TOOTHED BUCKET...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
