Engine Block Heater Charger
   / Engine Block Heater Charger #21
While I'm a fan of well-designed and properly used off-grid systems, unless I had other reasons (ex.pumping water) for siting a major PV array where the tractor sits, I'd use a portable gas generator.
Not sure about USA offerings, but Honda offers what they call Cold Climate Technology in Canada, aimed at dealing with carb icing concerns. (I don't sell Honda ;) , just one example of a gen that can deal well with Winter temps).
For OP's application, I'd secure a generator in the back of a truck or trailer for the wife to use - even a suitcase sized one would have enough power for a 500w block heater, and some also have 12vdc outputs too - with those I'd also set up quick connect to the tractor battery, and top up it's starting battery while running the block heater.
Won't claim it as my idea..... many contractors starting out of the way diesels in the dead of a Canadian Winter have been using generators for this for quite a while.
Rgds, D.
   / Engine Block Heater Charger #22
Most block heaters are in the 200-400 watt category.
Denver I believe gets lots of snow and enjoys rather cold conditions..........
Most of the snow on the East Slope comes in the Spring, 'cold conditions' as compared to what? After a snowstorm the sun usually melts it off in a day or so, plus the chinooks are quite frequent and vigorous ( 5 degrees F at sundown and 50+ by midnight) He lives there ....... Roger?
   / Engine Block Heater Charger #23
Google 'propane block heater' :)
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
13ft S/A Utility Trailer (A56859)
13ft S/A Utility...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
