Engine oil and filter once a year?
   / Engine oil and filter once a year? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Well ,my New Holland TN70A wants the oil and filter changed every 300 hrs. I run about 150 hrs a year, so I change my Rotella-T synthetic 5-40W and filter once a year in the late fall or early winter. What do you think?
Bob
   / Engine oil and filter once a year? #2
Sounds right to me. My JD5105 wants oil and filter every 250 hours, or 1 year, whichever comes first. The manual clearly says change oil and filter at least annually. I am running 111 hours since 3/1/07 (delivery) and just changed the oil for the first time last week.
   / Engine oil and filter once a year? #3
Be careful on time and hours and miles thing, lots of oil Mfg suggest a day/month thing not just hours on engine.
Jim
   / Engine oil and filter once a year? #4
Bob
I change engine oils..etc..according to USAGE and not a calender. If I do an oil change on ( name a vehicle?) on say Jan2...and do not operate that "equipment" AT ALL for ..again..lets say 11 months...Im "suppose to" do an oil and filter change on it in less than another 30 days? ???? That of course doesnt men I can do a oil change and let it sit ...without usage...for say 20 years.
Ive owned my Kubota for 2 years now...and dont use it anymore than 25-30 hrs A YEAR...and I just did my 50 hr service last week. ( BTW I installed Rot 5W-30 in it instead of 10W-30 Dino oil)
   / Engine oil and filter once a year? #5
Jim
Yep, that's one way to sell more oil.
I would trust the vehicle/engine/equipment manufacturer first. He has his reputation riding on his product, not to mention potential warranty costs, so he is unlikely to make unrealistically long recommendations, while still having an interest in economical service intervals, lest his customers go elsewhere.
   / Engine oil and filter once a year? #6
Depending on location I definitely recommend an oil change yearly! Here in the north east with the hot and the freezing cold the amount of moisture that can build up in the oil can kill it long before it's time. The water being heavier then oil will settle to the bottom and freezing will hinder any movement of the frozen water so the lack of lubrication will kill the machine!
Jim
I am not sure what this means, can you give me an example?
Bob
   / Engine oil and filter once a year? #8
Ive heard that theory before...but never an ACTUAL occurance in almost 60 years! If one had THAT MUCH water in his oil pan...he's got a lot bigger problems that "poor oil change schedules"..:eek:
   / Engine oil and filter once a year? #9
Bob
Sure, no problem, here is what Mobil says and Amsoil say and I'm guilty of leaving it in longer Shh
Jim
   / Engine oil and filter once a year? #10
Bob
I bought a new Ford 1910 in the early 80's. I have about 1300 hours on it now and it still runs like new and uses no oil. I change one a year in the spring. I use Delvac one.
   / Engine oil and filter once a year? #11
For rarely or seldom used equipment that is stored outside in non climate controled sheds I recomend a once a year oil change. As was previously mentioned condensation can build up in the oil over time. My concern wouldn't be that the water would freeze but that it will lead to rust and corrosion on internal engine parts. Also extended exposure to water can start to deteriorate/decompose some engine oil aditives.
   / Engine oil and filter once a year? #12
Sully, when the winter sets in and tractors are left out or just in the cold, started on a near daily basis for winter work, warmed and then cooled back to freezing the amount of water you can get in a hydraulic system would amaze you! Could some be from melted snow, sure it could but it is not unusual for us to find a couple of quarts on a single season.
   / Engine oil and filter once a year? #13
When it comes to oil life, I try to error on the side of caution for the car and the tractor. On occasions where I feel I am changing out synthetic oil before it's time I put the hand me down oil in the old lawn mowers etc. Left overs eventually get returned for recycling.
   / Engine oil and filter once a year? #14
Well..needless to say...with 50 hours in 2 years...it DOESNT get "started daily". AND...if water from "melted snow" is getting into my Hyd fluid...again...Ive got bigger problems that too long of a fluid change!!...:eek:
   / Engine oil and filter once a year? #15
My little tractore gets new oil and filters every spring just before I start mowing again. It doesn't cost very much and it's my ritual for going over everything. I mostly use that tractor for mowing, so it doesn't get allot of hours per year. Maybe twenty hours a month.
My backhoe and dozer take allot more abouse, so I changet the oil and filters on them twice a year. Spring time and August. I do it because of the amount of dust they deal with along with how hard they work. I don't pay attention to hours at all when dealing with maintenance.
The same is true with greasing. I grease before the tractors every time. It doesn't matter to me if I only used it a few hours the previous time, or ran it hard all day.
It gives me piece of mind.
Eddie
   / Engine oil and filter once a year? #16
Eddie
And I am at the other end of the spectrum. Im not dumping engine oil that has been run maybe 2 hrs. ( My driveway is 200 ft long. If it snows this winter...IF IT SNOWS I'll clean if off)..thus my "typical winter usage"
My tractor gets NO ABUSE. NONE. I most probably could accomplish every single task I have here in landscaping with a tiny BX22 or ?? Instead I chose a B3030..MUCH large and more powerful. I have no "PTO" run impliments ( didn borrow a PHD once to bore 3 holes) so I dont even have the "need" to run it wide open to get the 540 PTO speed. In fact the ONLY times it see's "wide open" is for road travel..the whole 3 miles to my farmer buddys place
Dusty enviroments? When I service my rig last week...and pulled the screen out that right in front of the radiator...it had ONE BUG stuck in it! I didnt even bother to blow it "clean" with an air hose. For my tractor to be working somewhere thats "dusty"..it means that "I" have to be working somewhere dusty. I dont have any jobs THAT important to get done
I fully grease my FEL every 5-6 hrs of FEL work (book says 10 hrs).
Ive called service managers for Cummins; Allison trannys and even Kubota..and prefaced my "questions" with.." I know what the BOOK says...but Im asking YOU"...and their replys have all been "dont worry about it"
   / Engine oil and filter once a year? #17
So you won't change oil and filter yearly on a $3,000+ engine, but you'll grease a $2 bushing prematurely? I don't get it.
I'm glad to see that service managers, most of which wouldn't know a metric adjustable wrench from a 2 foot yard stick, know more about the equipment than the engineers that designed it.
Am I being a wisenheimer here? Yes I am. I have found the best way to illustrate absurdity is with absurdity.
Jim
Thanks, very nice information.
Bob
So, that is just another reason for me to use my tractor every week!!!!!!!!
Bob
   / Engine oil and filter once a year? #20
Bob
Its the best way to go...IF you have a need to use it. I cant see just starting mine up and running arond the property for no real reason.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
