Engine oil
/ Engine oil #21
I vote for Delo 400LE. I have used it for 40+ years in all types of engines from stationary diesels to lawn mowers. It was originally developed for stationary industrial and marine engines and has been a consistent product over the years. I would not use in in the high tech specialized automotive engines though. On those the manufacturer's have specific requirements and recommendations. A Diesel rated oil works fine for gas engines but not the other way around. I use 15-40 in the tractor and the cars and trucks as we have mild winters up here.
Ron
/ Engine oil #23
I vote for Delo 400LE. [snip]
Ron
Where do you find Delo 400L? The nice thing about Shell Rotella T6 is that I can find it in any Walmart, TSC and most auto parts stores in the country. I'm never seen Delo, but then again, I've never looked either.
Thanks,
/ Engine oil #24
Thanks,
Walmart carries it along with Rotella, Delvac, Mobil 1 Diesel, Valvoline Blue Diesel oil, and Castrol Diesel.
Many choices out there.
Chris
/ Engine oil #25
Thanks,
walmart carries delo.. at least mine does. it caries the ford powerstroke orange bottle 15w40 as well.
I now use valvoline ultra blue premium syn 5w40 love it.
/ Engine oil #26
I buy it at NAPA. With my military/fleet discount it is very reasonable. It is amazing that I get 45% discount and they still make their profit target. COSTCO also carries it. If you have a farm/business you should be able to get the fleet discount at NAPA. I have it covered on both ends as on some things the military discount is higher.
Ron
/ Engine oil #27
Ok thanks!
Is the Delo dino or synthetic? I prefer synthetic.
/ Engine oil #28
It is dyno. Some of the new cars and smaller stuff are required to use Syn 0r you void the warranty. I do not have any of those. Cannot justify the additional cost, and would never put Syn in an engine unless it is new and start out that way. Too many horror stories out there on that scenario.
Ron
/ Engine oil #29
And that's all they are .. Stories. I've started vehicle engines on synthetic with 40-50K and have never seen any problems
/ Engine oil #30
Yep. Dino oil has closed the price gap on synthetic oil. Just yesterday I was at my parts store. $21.99 for dyno oil change and $27.99 for synthetic. Thats a no no brainer to me. 5000 miles for dyno and 10000 for synthetic in my vehicles.
I think in the next 10 years dyno oil will be all but vanished except for special applications.
Chris
/ Engine oil #31
I bought my '03 impala with 37k and put whatever the dealer changed the oil with. At 100k I started using valvoline synpower and now have 205k. Started leaking oil from valve cover gaskets around 150k and at the same time changed lower intake gasket because it was leaking coolant. That's the only time I've touched the engine. I don't see any indication it won't go to 250-300k...
I plan to drive it into the ground then open the engine to inspect. Probably won't be for another couple years, but I'm sure I'll have a full write-up here.
/ Engine oil #32
Agree.
/ Engine oil #34
Agreed..............
I have used AMSOIL synthetic oil since 1975 and I have heard just about every BS horror story on synthetic oils. Not a !@#$%^&* one of them is true, just myths spread by those who have an axe to grind.
What we don't understand we fear, and what we fear we put down.
/ Engine oil #35
I'm gonna call you on that one.
I emailed amsoil and asked them if it was ok to put their product in a 30-50's era antique tractor.
the response I got was that due to possible seal and gasket incompatibilities, they did NOT reccomend use of their product in an engine that had not been rebuilt with new-er gasket and seal materials of more recent vintage than I was working with.
So.. some of those 'myths' that you are claiming 100% false.. may just have a shred of truth to them. I realize the amsoil official reply is probably more of a CYA statement.. .. however.. CYA statemetns are due to liability.. and liability many times has limited basis in actual problems.
Soundguy
( fyi, I'm running synthetic oil in a mid 60's tractor that i rebuilt the top end on.. IE.. new head set... no problems... )
/ Engine oil #36
Try 188k on an '06 Sierra 4.8L...
Still going strong at 225k running Mobil 1 5W30 syn
/ Engine oil #37
Soundguy
Really?
Seal technology has come a long way since then.
Detergent oils were mostly non-existant before WWII so massive sludge deposits were the only thing standing between merely small leaks and horrendous oil leaks. After a thorough purge by the new high detergent synthetic oil, increased oil leaks are a very high possible outcome.
How many times have there been posts in this forum from people looking for non-detergent oil for their old tractor? Any detergent oil used will most likely clean the engine and remove the crude and lead to the seals leaking BECAUSE the seals were INFERIOR back then.
I first used AMSOIL in a NEW 1975 Chevrolet K5 Blazer and it never leaked oil in the 5 yrs or so I had it.
/ Engine oil #38
kenmac, can you provide a UOA to confirm that Amsoil is better than Delvac S?
I can't provide that info for you. I have never run/used Delvac S. I'm sure if you were to visit some of sites that discuss oil ( a lot deeper than they do here),you'll find someone that has that info
/ Engine oil #39
i use detergent oil in ALL of my antiques. I have never experienced a massive filter clogging rush of junk falling loose. or spontaneus oil leaks.
I usually even run tranny fluid ( old f or m/d-3 ) in oils to HELP celan the engine up a bit.
the worst one i've ever done was a jd-B that actually got 5 oil changes and fitler changes in 1 week due to a massively dirty and emuslified engine.
past that it was fine.
I have a mid 60's era tractor I switched to synthetic oil after a head rebuild..
Really?
/ Engine oil #40
Rotella is ok but there are better oils for the same money. Delvac, Dello 400, ect. Any in 15W40.
Rotella is the McDonald's of oil.
Chris
Thats funny.LOL.Show your proof?I have used rotella,delo,Valvoline prem.blue and delvac with the same results in my diesel trucks,mowers and tractors.
