Oil viscosity change for a 5.7 Hemi?
   / Oil viscosity change for a 5.7 Hemi? #21
I would not change the cold viscosity from what it is. Oil flow at cold starts is important, especially with all the components that function with oil pressure. I wouldn't hesitate to run a 5W-30 though. My old 5.4 3V Ford V8 was switched to 5W-30 at the recommendation of many experts when I got the truck at 50K miles, when I had the engine open at 120K to do preventative work it had no wear and the phasers, chain tensioners, cams and followers were all in perfect shape. Proper oil change intervals and good quality synthetic oil are just as important as the oil weight in my opinion.
   / Oil viscosity change for a 5.7 Hemi? #22
I live far rural and on any drive it involves some amount of highway speeds. I had a 2005 Charger with the 5.7 for trips to town or the far away big city. The cylinder deactivation worked fine but did zero or very little for mileage. I later traded it in for a 2007 Charger SRT8. For all the horsepower that SRT8 had, if I kept my foot out of it, I lost only 1 or 2 MPG on the same roads and under the same driving habits. But it needed premium and that stunk. And if WAS hard to keep my foot out of it ;)
As for oil and protection/longevity you said you are already running 100% synthetic. Excellent. DON'T change the specified oil weight, in my opinion. Both the 5.7 & 6.1 are good engines.
  • Good Post
Reactions: JJT
   / Oil viscosity change for a 5.7 Hemi? #23
My 07 ram hemi took 5-20 oil and if i put in 10-30 it would throw a code
Well after all the discussion and opinions both here and other forums I think I'll stick with what I've got, 5W-20 synthetic. There are conflicting views and both ways have valid, good points but I think the leave it as is is the better idea. Not by a landslide by the majority LOL.
   / Oil viscosity change for a 5.7 Hemi? #25
The new oil pumps in some new engines are HVLP pumps. They have gotten away from gear pumps for oil pressure.
A heavier viscosity oil could backfire depending on how fast on engine startup the new style High Volume Low pressure Oil Pumps would build operating oil pressure.
That being said I am old school in not liking these low viscosity oils especially on the crankshaft. That film of oil is important in my thinking.
   / Oil viscosity change for a 5.7 Hemi? #26
Everyone has pretty much hit it on the head. The MDS requires the 5w-20. You can turn off the MDS but starting I think in 2016 the computers are locked. You can get around it by getting an unlocked pcm and get a programmer but you’re getting over a $1000. You can delete the engine, it’s not difficult but you have to crack the engine open, not simple either.
I have a 2010 Dodge Challenger and turned off the MDS with a programmer. I was a little surprised by how much it hurt fuel mileage, I’d say 10%. They have improved the programming on the MDS, on my 2010 it’s was very annoying, turning off and on a lot. On my wife’s 2019 300c, it’s much better.
Most legitimate 5.7l “tick” problems at idle are caused by broken exhaust manifold studs, allowing a tiny bit of exhaust sound to sneak past the head/manifold interface, but most folks blame the MDS system.
MDS isn’t even active at idle.
At idle, the MDS lifters are locked up, like a normal lifter
Most vehicles allow de-activating MDS by simply pressing your electronic shift button to the highest manual “gear”. Of course you unfortunately need to do this every time you change to “D”.
   / Oil viscosity change for a 5.7 Hemi? #27
Tow/haul mode also deactivates MDS.
   / Oil viscosity change for a 5.7 Hemi? #28
I was trying to remember it there was a way to disable 'MDS' on the 5.7L Charger. I'm pretty sure it didn't have a Tow/Haul mode ;)
   / Oil viscosity change for a 5.7 Hemi? #29
Most of the Hemi cars, be it a Challenger, Charger, or 300 have a way to manually shift. The older ones had Autostick, you slap the shifter right or left to shift up and down. This keeps the MDS turned off. Going down the highway it’s not an issue but if you pull up to a stop sign it will try to hold 1st gear when you pull away. Full throttle it will upshift in autostick automatically but most people don’t drive that way.
It’s the same way with paddle shifters the newer models have. Use the paddles MDS is turned off.
   / Oil viscosity change for a 5.7 Hemi? #30
As someone who has a 19 Ram 1500, 5.7L; that also has destroyed two work truck ram 1500, 5.7L hemi. Idle... They don't oil well at idle. Avoid just idling. Yeah, a minute here and there, fine, but avoid those 30 minute idles while wife is in the store, or letting it warm up for an hour while you do other things.
Keep in mind those work trucks often idled for hours and hours. Sitting working on computer, waiting on a crew, eating lunch, waiting out bad weather, ect. They both got 5000 mile or 7500 oil changes, but how many hours was that?
   / Oil viscosity change for a 5.7 Hemi? #31
Many Many moons ago when I lived in Wisconsin even when
the; temps went -35F I used 10W30 reg oil in all my vehicles
year round and never had any problem starting in the cold
mornings.
synthetic oil generally sticks to engine components better than conventional oil when the engine is off, offering superior engine protection. This is due to the superior film strength and stability of synthetic oil, meaning a greater amount of oil remains on the engine parts after the engine is shut down. This helps to reduce wear and tear on the engine during startup, when most wear occurs
willy
   / Oil viscosity change for a 5.7 Hemi? #32
mornings.
willy
Back in those days engines were much different. The clearances were not as tight and the valvetrains didn't rely as heavily on proper immediate oil pressure to function like modern variable valve timing, overhead cams, chain tensioners ect. Not to mention the need for modern turbo engines to have the correct weight oil for proper oil flow. Oil quality, weight and maintenance is easily the top contributor to modern engines lasting or not.
   / Oil viscosity change for a 5.7 Hemi? #33
If worried about oil on bearings and such, a '19 should have the option of holding the gas pedal to the floor during the normal starting procedure.
Doing that cuts the fuel off, so the engine turns but doesn't start. I give all our FCA/Stellantis vehicles a few seconds of letting the engine build pressure before starting them.
   / Oil viscosity change for a 5.7 Hemi? #34
The recall of the GM engine and the 'warranty' fix of going with a heavier weight oil got me thinking. I've got a '19 Ram 1500 with the 5.7 Hemi, 90K on it now and it calls for 5W-20 oil which I've always used. Seems as if one of the problems with this engine is flatspotting the roller lifters. I do an oil analysis every oil change and there's no wear or non to speak of nor particles in the filter.
What's the collective thoughts of going to a heavier oil say a 10W-30 or a 15W-40?. The lighter oils were supposedly spec'd for mileage which I find hard to believe oil viscosity will make a hill of beans difference on a warm engine. My concern is oil flow at lower temps. Summer's not so bad but winters get as low as -10C around here and I don't want to cause starvation issues. Even saying that, I would think there's more than enough residual oil left on an engine to lubricate it during a cold start until the oil starts flowing. Thoughts?
The Pennzoil Ultra Platinum 5W-30 is a 'lighter' 30w (lower end of the 30w viscosity scale) and is what I used to replace the 5W-20 recommended for my 2019 F-150 5.0. Not only did it quite it down some, I am getting better MPG and upped my 'avg' by .5 over the last 6 months or so without resetting it.
20w is just way to light for a working truck, IMO.
   / Oil viscosity change for a 5.7 Hemi? #35
I wish I still had the SRT8 to verify your info. Had to sell it as it needed 8" of ground clearance to get to our retirement home.
   / Oil viscosity change for a 5.7 Hemi? #36
I’m pretty much 100% positive using the autostick or paddle shifters turns MDS off. We have had 3 Chrysler 300 C and one challenger. Same with using tow haul in the trucks.
   / Oil viscosity change for a 5.7 Hemi? #37
That’s actually interesting. I’ve always viewed it totally opposite of this. I’ve always figured, the quicker and engine fires, and gets up to speed, the better. I’m pretty sure starter motor driven , crankshaft Rpm’s are slower than your minimum idle speed required for adequate oiling of the entire engine.
You’re still spinning all the components either way, if there’s no good oil on surfaces at a quick start, there’s the same, no good oil, while you’re slowly turning it over against compression, and valve lift.
I’m guessing the difference is negligible either way.
   / Oil viscosity change for a 5.7 Hemi? #38
A drill motor turning just 500 rpm will circulate a lot of oil when prelubing an engine.
Now that is using a distributor body or a drive tool
   / Oil viscosity change for a 5.7 Hemi? #39
Yeah, turning just the oil pump is one thing . That’s totally different than cranking an entire engine assembly with compression strokes using a starter motor.
I think people confuse the two.
   / Oil viscosity change for a 5.7 Hemi? #40
OK, to put it in a tractor content. With mechanical pressure gauges on tractors and trucks I have seen oil pressure on the gauge before they started while cranking.
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Hydraulic Concrete Breaker Excavator Attachment (A59228)
Hydraulic Concrete...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
ATHENS PLOW CO. 55-7' DISC HARROW (A60430)
ATHENS PLOW CO...
