IH3444
Veteran Member
- Joined
- Jan 10, 2004
- Messages
- 2,114
The reality show could be called.
The Man I Wish Was My Brother
lol, those ARE my clean clothes!
No really, it's always so dirty and greasy even clean clothes would look like that in about 5 minutes.
I'm leaning more and more towards leaving the pistons in and not balancing them.
Of course I still don't have the bottom end opened up yet. I hope I haven't let anybody down if I make that decision. But man, there is a lot of work removing just that front timing gear cover and housing. I'm not looking forward to remove the head at all. I'm still confident that the scoring on the old crank journal is the reason for loss of oil pressure. That's why I'm replacing it. Now, with a new pump and crank and new bearings, the bottom end should be good.
Leaving for work today, so I won't be posting until Wednesday.
See you guys later.
Thanks Cyril,
I appreciate that.
Before I leave today, I will try to get the bottom off. I'm leaving the oil pan on since all the bolts holding the engine and what they call "main oil housing" are separate from the pan. I need to get that off to get to the journal caps. But like I said, I will look at if it is possible to remove the pistons safely without damage. But more important, that I can install them safely. If I don't feel confident about it, then I'll leave them in.
Curious as why you didn't use the original timing marks ?the first thing I did was mark all the gears that would be coming off.
After taking the cover off, the first thing I did was mark all the gears that would be coming off.
Maybe you can see the markings in the close ups? That way, I can line up the meshing teeth exactly the same as when they came off.
