Oil & Fuel Engine Using Oil
/ Engine Using Oil #1
bill18163
NW Pennsylvania
Kubota B2710,BX1860,LA3940
I have a BX1860 that my wife uses to cut our grass. That's all this tractor is used for,just to cut the grass. It has 80 hours on it. The engine burns some oil. I found it down half way on the dip stick once and about a fourth of the way down another time. I have two other Kubota tractors, a L3940 and a B2710 and they dont burn a drop of oil between oil changes. Could this be something particular to the smaller Kubota engines? Anyone else seeing this in their small Kubota tractor?
/ Engine Using Oil #2
Has it always used oil? (e.g., rings never really seated properly)
Or is this recent? (e.g., broken ring?)
/ Engine Using Oil #4
If you don't find the problem, some "Lucas" additive at oil changes will probably stop that small amount of usage. Ken Sweet
/ Engine Using Oil #5
I bought a BX2200 in 03 and sold it to my son in law when I bought my BX2660, neither has burned any oil.
/ Engine Using Oil #6
Bill, I guess a lot depends on how often you've been checking the dipstick when you find it 1/4 or 1/2 down. Between oil changes that amount wouldn't be abnormal on a new engine.
/ Engine Using Oil #7
Sounds like the rings need to be seated. Make sure you get the unit up to operating temperature and then go mow some really heavy grass, make the engine bough down a little bit, see if that helps.
/ Engine Using Oil #8
Yes it sounds like a bad break in. Get your self some JD Break-in oil and use it till it stops using oil then switch back to your regular oil. John deere recommends doing this for engines that got a poor break in. Also make sure to work it hard and up to temp as it is temp and pressure on the rings that makes them seat.
/ Engine Using Oil #9
Are you saying you should work the engine hard to break in properly? I think my manual said to try to not run the engine at high RPM's for the first 50 hours.
/ Engine Using Oil #10
Just going on what Deere recommends. That is to gradually ramp up to 75-80% load after a brief run in which is usually done on a dino of about 2 hours. The idea is to get enough heat and pressure on the rings for them to seat properly.
I have done this with several large JD engines and have had good luck. None ended up burning oil at all. Don't see why a Kubota would be any different. I have run in multiple Kubotas using JD's method and none of them burn a drop.
Idling a new engine will cause problems so after warm up put them to work.:)
/ Engine Using Oil #12
Yes, you are both correct.
You can, and should, work the engine hard (after proper warmup!) AND this can be done without using high RPMs. Kubo never said to run it wide open, and he is correct that the rings need pressure (from being under load) to seat. Diesels are slow to seat anyway. You should also avoid running it at a constant rpm for an extended period of time; adjust the throttle occasionally.
At the same time, do NOT lug it... use a high enough rpm to do the job. It needs a load yes, but making it struggle will lead to other damage.
Trying to baby a new engine only causes the rings to wear without really seating, and that leads to compression loss. Eventually they'll seat but some of their useful life will be already spent.
/ Engine Using Oil #13
On Engine rebuilds, We always seat rings on the Dyno, while varying the throttle and Dyno load, during the process. Ken Sweet
/ Engine Using Oil #14
That sounds "Cool":thumbsup:.....are they tested on a test fixture out of the tractor or on the tractor tested thru the drivetrain?
/ Engine Using Oil #15
Through the drivetrain, That lets us checkout the PTO as well. Ken Sweet
/ Engine Using Oil #16
I agree for the most...I say use it like you want. I did not follow the manual on the new kubota (BX24) and neither on my old 22. Never had an issues (using oil etc). Even new diesel trucks, cars etc.
My current BX24 over 250 hours does not move off the stick and break-in, what is that...
But, if the guy as a slow break in whom cares. Yea more wear could happen but what is that in the long term? 10000 to 1, not gonna mean a thing. He might get higher wears if he did UOA and some extra fuel lose. I would worry more about the War of the Worlds then this...LOL
New/Unused ATS 60 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 60...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2011 CATERPILLAR 304D (A65643)
2011 CATERPILLAR...
