engine won't turn over
/ engine won't turn over #1
harryhill
Broadway, VA
john deere mower X300
I have JD X300 with 6 hours on it. I started the mower right back it out and put a snow blade on it, Went to start it and it would not turn over. Battery shows 13. amp. I replace all fuses and relay and it still turn over. Any ideas? Thanks
/ engine won't turn over #4
I would check the PTO switch and make sure the brake is on.
/ engine won't turn over #5
Take the snow blade back off. Put the mower back on.
Put in neutral, pto off, put 45 lbs on the seat and turn the key. It ought to start then.
/ engine won't turn over #7
Sounds like an interlock. Maybe one got a wire knocked loose when the blade was put on?
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A59911)
2012 FREIGHTLINER...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
Harlo HP6500 (A60462)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
