engine won't turn over
/ engine won't turn over #1
harryhill
Broadway, VA
john deere mower X300
I have JD X300 with 6 hours on it. I started the mower right back it out and put a snow blade on it, Went to start it and it would not turn over. Battery shows 13. amp. I replace all fuses and relay and it still turn over. Any ideas? Thanks
/ engine won't turn over #4
I would check the PTO switch and make sure the brake is on.
/ engine won't turn over #5
Take the snow blade back off. Put the mower back on.
Put in neutral, pto off, put 45 lbs on the seat and turn the key. It ought to start then.
/ engine won't turn over #7
Sounds like an interlock. Maybe one got a wire knocked loose when the blade was put on?
CHRYSLER V8 GAS ENG (A63291)
CHRYSLER V8 GAS...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2022 EZ-GO ELITE...
