Engineering questions - steel laminate beams
   / Engineering questions - steel laminate beams
So imagine this is my shop, only the middle is roughly twice as wide, and a bit taller on both levels.
   / Engineering questions - steel laminate beams #52
joe - if you don't mind, can you get me the size of the beam? I have to span 21' or so just as you did, except the span on each side will be right around 17' instead of 14'. I plan on doing it in the same manner as yours was done. Each end will bolted with steel plates to a 10"x10" oak post.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
